Old 05-08-2015, 09:02 AM   #1
Jim34RL's Avatar
12V Battery compartment
OK; here is another issue that I have. Does the standard 12V battery that is shipped or provided by the dealer is this fastened in place? When I brought my trailer home from the dealer, I notice that the batter tray was not fastened to the battery compartment floor. A strap was provided but this was lose and not attached to anything. In fact there was no opening for a locking mechanism or fastening device for the battery tray at all. Thus the battery is allow to shift around when you are traveling and will damage the compartment eventually by sliding around.
I could provide a device but was wondering what others have done?
My temporary fix is two heavy duty industrial Velcro fasteners under the battery tray for now.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 05-08-2015, 09:28 AM   #2
TURBS's Avatar
Battery is supplied by the dealer.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-08-2015, 10:08 AM   #3
TT or 5er??????????
Jim in Halifax is offline   Reply With Quote
Old 05-08-2015, 10:29 AM   #4
Former Full Timer
Duckogram's Avatar
In your previous post you stated you have a Residential Fridge. If that is true and you have an inverter, you should have 4 each 6v deep cycle batteries. They fit in the tray and do not need straps as they cannot go anywhere.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 05-08-2015, 11:41 AM   #5
Jim34RL's Avatar
Originally Posted by Jim in Halifax View Post
TT or 5er??????????
I thought my signature would tell you what type of rv it is a 5er.
Jim W.
Old 05-08-2015, 11:48 AM   #6
Jim34RL's Avatar
OK I understand that but as I am almost max out on this years discretionary spending for the year. I am using the one 12V interstate battery that the dealer provided. Also we do not boondock, DW wishes we will be on shore power except to travel and the inverter with the battery should be sufficient for on the road when traveling.
Jim W.
Old 05-08-2015, 12:00 PM   #7
I think the comment is more to the point the dealer should have put 4 6V batteries in that unit.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-08-2015, 12:13 PM   #8
dieselguy's Avatar
None of the dealers that I've been to out here around KCMO and Wichita, KS include 4 6VDC batteries for the units equipped with a residential fridge ... just a single Interstate 12VDC and no battery box. I bought a battery box from Wally World, placed the battery in it and screwed the straps to the compartment floor. I don't have the residential fridge, but I was stating my solution to the battery hold down.
dieselguy is offline   Reply With Quote
Old 05-08-2015, 03:53 PM   #9
racer4's Avatar
FWIW, here is the first thought that popped into my head.
Cut a piece of plywood to the full size of the floor of the battery compartment. Put a standard battery box (Walmart) in the middle of that plywood and keep it from sliding by screwing some 1"x1" wood strips to the plywood on all four sides of the box.
Use the strap and plastic tie down brackets that come with the battery box to strap the box down to the plywood. The "brackets" can be screwed to the plywood. This way you are not putting any holes in the battery compartment floor.
Is the battery compartment floor fiberglass?
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually, 4.10 axle, Auto Flex Air Ride Rear Suspension
2017 Cedar Creek 36CKTS, Disc Brakes
racer4 is online now   Reply With Quote
Old 05-08-2015, 06:15 PM   #10
Former Full Timer
Duckogram's Avatar
I bought my 36CKTS from Nationwide RV, 10 miles East of KC, MO. It came with 4 Interstate 6V Deep Cycle Flooded Batteries. I know that the Thompson Bros sold out to CW so I will assume the business model has deteriorated.
battery
