Old 04-18-2016, 07:12 AM   #1
'13 29RE Fridge Lights Flashing
The fridge control lights (external, above freezer door) recently were flashing. I also noticed the LED next to the 20A fuse was flashing. I pulled the fuse and noticed it seemed charred on one side. I replaced the fuse which seemed to correct the problem, other than the LED next to the 20A fuse was dimly lit solid. The unit ran over night and the same flashing issue (Fuse LED and control lights) returned. The unit is now off to prevent further damage. Any ideas what this might be?
jhuval is offline   Reply With Quote
Old 04-18-2016, 09:03 AM   #2
dieselguy's Avatar
12 VDC powers the control board on the back of your fridge, operator panel, and solenoid that opens your gas valve ... 120 VAC runs the electric heating element ... propane fuels the burner. I'd check all visable electrical connections on the back of your fridge as well as making sure the ground(s) aren't corroded. It may just be that simple or it may be your control board is flaking out. You might even go as far as pulling your fuse/braker panel out as far as you can and check all wiring connections on the rear for looseness. I've seen several units with loose neutral wires. Have camper unplugged from A/C power and battery disconnected if you do this.
dieselguy is offline   Reply With Quote
fridge, light
