Old 04-19-2016, 06:20 AM   #1
wls
1st Trip
This coming Sunday, we will be setting up in a local campground for the first trip. Question I have when I hook up to city water, is there anything I have to do as far as the residential refridgerator (Whirlpool)? Do I put the filter in, or run it first with the by-pass plug in? Also as far as the ondemand hot water, does anyone have a pic of the way the valves should be turn to have hot water, I'm assuming that the water heater is in bypass, for the winterization.
I'll take a pic tonight, of the valves for the hot water, and see if I can post on here. Thanks
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 04-19-2016, 06:35 AM   #2
bubbles's Avatar
Do you have an on demand water heater or do you have a standard tank water heater? Apples and oranges. I believe there may be no winterization (by-pass) valves associated with the on demand system. If you have the tank system turn the 2 valve handles in the water lines going to the water heater so they are in-line with the lines and turn the valve handle in the line that goes between the 2 water heater lines perpendicular to the line. Your set.
Old 04-19-2016, 09:41 AM   #3
wls
I'm sorry I forgot to mention we have the on-demand system
Old 04-19-2016, 10:14 AM   #4
bubbles's Avatar
You did mention it but you also mentioned by-pass valves for winterization and I haven't seen any reference on this forum for by-pass valves associated with the on-demand system. There may be and someone with knowledge of this type system should chime in.
Old 04-19-2016, 11:08 AM   #5
wls
Ya guess I did, but I agree I don't really see a reson to bypass the on-demand
Old 04-24-2016, 09:36 AM   #6
MNtraveler's Avatar
Here's a discussion of an on-demand water heater with no hot water due to being left in winterization bypass mode. Also it has a drain valve. On-demand doesn't mean the hot water heater doesn't hold water in a small tank. For that small tank, bypass keeps the antifreeze out for taste and smell, also it's not needed because the tank can and should be drained.
No hot water
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 04-24-2016, 12:58 PM   #7
97flhtcui's Avatar
wls, good luck with your camping trip.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 04-24-2016, 08:24 PM   #8
JohnF's Avatar
My unit with demand hot water heater and valving.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 04-25-2016, 06:49 AM   #9
wls
well we are on the trip, camping about 8 miles from home. Everything is going good, hot water, refridge working, making ice. Thanks
Old 04-25-2016, 07:27 AM   #10
That's a nice valve system and easy to get to. Mine is a pain to get to behind the pass thru storage. I have to remove a wall. Why can't they all be made this like?
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is offline   Reply With Quote
