Old 12-31-2013, 11:07 AM   #1
2 stage Cavagna group 924N
I have a 13 30RL C/C and I have found out that when the 2 stage Lp regulator switches from the empty tank to the full one it leaves a half a gallon of LP gas in the empty tank. The regulator is a Cavagn group 924N. I found it has a set screw in the regulator, I have looked at there web site but I can find out nothing about the screw, does anyone on here know. It leaves a half a gallon each time when the tank is suppoused to be empty
spock123 is offline   Reply With Quote
Old 12-31-2013, 11:13 AM   #2
Old Enough to Know Better
gasman6674's Avatar
It is based on pressure not liquid level. Regulator switches when "supply" tank drops below 10psi. The set screw is for downstream (outlet) pressure and unless you have a manometer or a gauge that reads inches of water column I would not advise touching it
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 12-31-2013, 12:12 PM   #3
I don't know anything about regulators, on my last campers the tanks would always empty out but not on this regulator. I have to take the C/C back to C/W to have it worked on and I guess I can ask them and let them check it out
