Old 11-09-2015, 03:07 PM   #21
The gas is on a wall switch. It controls the ignition module down by the back of the water heater in the cabinet. It needs 12 volt power from a fuse in the panel.
The electric is a rocker switch inside the water heater itself. It is wired to a 120 volt breaker in the main panel
Harkerr is offline   Reply With Quote
Old 11-09-2015, 03:12 PM   #22
MNtraveler's Avatar
Originally Posted by TruckingJohn View Post
Thank you all that tried to help with this issue. I was confused by the pictures posted as the switches for the DSI all had reset buttons along with the switch. Mine is strictly the switch and light showing whether on or not and thus was making me assume it was not the correct switch but after finally getting the air purged from the line I have a flame burning in the WH with this switch turned on.
I guess this is just old enough to not include the internal reset along with the external (high temp) resets.
Well it just goes to show as a guy once told me don't go looking for zebras when there's a horse right there in front of you. Purge the propane line and get a good flame - and don't we love a no repair bill fix?!
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-09-2015, 05:31 PM   #23
toslow's Avatar
Originally Posted by wmtire View Post
Yes, the resets you are referring to are built into the combination thermostat/ hi-limit emergency cut off. These are on the face of the water heater so to speak.
Since you have a dual source water heater (propane and electric), that operate independently of each other, then you also have two thermostats/eco's. One for the propane/dsi and one for the electric heating element.
The thermostats are what cuts power to the water heater (either 12 volt DC or 120 volt AC when the water has heated to a certain preset temp. This is just like any thermostat in say your furnace, air conditioner, etc. Usually this is around 135 degrees for the water.
Now the emergency cut off (ECO) or hi-limit cuts the power when the temp get too high in the tank, as when the thermostat failed to cut off the power, or possibly another reason, like no water in the heater. This is designed to keep from burning up the wiring and I think the ECO trips around 160 or so degrees. if the ECO trips, you have to manually reset it, before power can once again flow to either your 12 volt gas solenoid, if that is the eco that trips....or your 120 volt electric heating element, if that is the ECO that trips. Both may be tripped if something has happened that would allow the temp inside the heater to get to 160 degrees.
To reset one or both of these ECO's, go outside and access your water heater. The ECO's are covered with a rubber plug. All you have to do it to press the resets on the ECO's thru the rubber. That's all. No need to remove the rubber cover, unless you have to replace the combination thermostat/eco. If I recall, the left hand one is for the electric, and right hand one is for the propane...but don't quote me on that.
Once you verify the hi-limit ECO are not tripped and you manually reset them, you can once again go inside and try to start the propane with your DSI switch and see if the propane lights up this time. It usually takes 15-30 seconds after you turn on the DSI switch before it ignites. You will hear a rapid clicking noise at the water heater as the DSI is making sparks to ignite the propane. If it lights, then the burner comes on the water heats up.
If it fails to light after a few seconds, then the DSI can attempt to light it again after a few seconds, and you can just wait to see if you hear it clicking again. After usually 3 failed attempts, the the DSI goes into a lockout mode. It will not attempt to light again, until you turn the inside switch off. then on again to start the process anew.
Not all of the older Suburbans would try 3 times though and yours may lockout in less than that.
If you look at the pic above, the DSI electrode that makes the sparks, is at the end of that orangish wire in the bottom right hand side of the pic where the burner tube goes into the water heater..
see thel ittle black on off switch down by the place where the propane screws in to the alumimin block and feeds the tube, it needs to be turned on
haven a blast
toslow is offline   Reply With Quote
Old 11-10-2015, 12:36 AM   #24
The light next to the switch is only on when the wh is in the ignition process
Old 11-10-2015, 02:39 AM   #25
wmtire's Avatar
This "only on" part needs a little more clarification. The red light comes on during the ignition process, as you stated...and does go off once the propane ignites. HOWEVER, it will STAY illuminated should the propane fail to ignite, and the system goes into lockout mode. The light alerts you to a problem....and thus the "DSI Fault" or lockout needs to be "RESET" designation for the red light on the switch assembly.
It is more fully explained in the service manual on pages 10 and also on the flow chart on page 18.
http://hometips.me/Mar/Suburban_Wate...ice_Manual.pdf
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-10-2015, 07:30 PM   #26
The lighted switch beside the sink is probably the 12volt switch for the water heater. You should be able to check and see if it turns on the 12 volt power to the water heater.
If yes, then you have a problem with the propane feed to the water heater.
kenenn is offline   Reply With Quote
cedar creek, washington
