Old 08-19-2014, 10:57 AM   #1
2012 36 re motorized tv mount
My 2012 36 re motorized tv mount is not operative, any suggestions?
Pls respond to dwolach@gmail.com
dwolach is offline   Reply With Quote
Old 08-19-2014, 11:24 AM   #2
Crusader's Avatar
Is it a Lippert TV lift ? If so it could be the switch, control box, or trans/motor. I have a Lippert lift, trans. was bad.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 08-19-2014, 11:33 AM   #3
How to find out if it is a lippert lift?
Old 08-19-2014, 11:37 AM   #4
Crusader's Avatar
The control board is marked Lippert .
Old 08-19-2014, 11:59 AM   #5
It is a lippert, but I can not read the serial number without removing the fireplace.
Old 08-19-2014, 06:29 PM   #6
Crusader's Avatar
There is a re-set button on the control board. If that does not work, bi-pass the switch and see if the tv goes up. If it goes up, the switch is bad. If the above does not work it's the trans/motor. I banged on the trans., And it started working again. I have a seven year warranty, so I had the tran/motor replaced.
Old 08-22-2014, 03:29 PM   #7
A couple of jabs with a broom handle temporarily solved the issue, although a new motor will be needed shortly. Thank you Crusader for your assistance.
Old 08-23-2014, 08:57 AM   #8
Crusader's Avatar
Amazing what a broom handle can fix !!
2012, mount, tv mount
