Old 08-11-2013, 08:53 PM   #1
BoatDude's Avatar
3 hanging lights
We lost 2 of the three hanging lights over the island sink on our new 36 ckts a few minutes ago. Tried to remove the bulbs and wow.....could not unscrew or twist them out. The hole fixture turns while turning the bulb. Anyone replaced these bulbs? Is there a trick to removing the darn bulbs?
2013 36 CKTS
2014 Ford F350 CC/DRW/PSD/Lariat/
Factory Installed Reese Custom 25K/
ReTrax Pro Cover
BoatDude is offline   Reply With Quote
Old 08-11-2013, 09:16 PM   #2
It wasn't easy getting these bulbs out, but I pushed the bulb up, and turned it just a bit. That did the trick. Good luck!
Mike & Nan
2014 Cedar Creek 36 CKTS
2013 Ford F-350 4X4 Dually
Mike&Nan is offline   Reply With Quote
Old 08-11-2013, 09:51 PM   #3
Vinster30's Avatar
Had to replace one about a hour ago. You may want to wear a glove, however, you do just push up a small amount, then twist. It should drop out at that point. Just as Mike&Nan stated.
Vinster30 is offline   Reply With Quote
Old 08-11-2013, 10:25 PM   #4
Same problem, put on leather gloves, pushed up, turned and finally the bulb came out. Odd bulb, had to go to 4 or 5 places to find a replacement. Also put a thin coat of dielectric grease in the socket and around the base of the new bulb to help with next removal.
Sirsea is offline   Reply With Quote
Old 08-12-2013, 12:59 PM   #5
BoatDude's Avatar
Got them out...thanks for the tip.
2013 36 CKTS
ReTrax Pro Cover
Old 09-05-2013, 02:03 PM   #6
I tried everything to get mine out after a burnout. Couldn't budge it! Then after a road trip, while setting up, I noticed glass pieces on the floor and the base of the bulb sitting on the counter top. Dang thing FELL out!! Go figure. Now a second one has burned out. I'm gonna wait until I get it up to the factory and get them to replace it. Maybe it will fall out too. Bulbs should not have burned out that fast. New unit in March.
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
WeRCreekers is offline   Reply With Quote
