Old 02-03-2013, 09:13 PM   #11
Rich and Char
rich and char's Avatar
Originally Posted by Earth Station View Post
X2..... love that idea!!! wonder..... can it be applied to the shower walls??? How often should it be reapplied????
I'm not sure if I would apply it to shower walls? But I will tell you that I use that CLR cleaner (bath & kitchen) on our shower wall. It takes away that calcium, lime and hard water deposits. I love it! Just spray on walls, wait about 5 mins, wipe & wash away!
2011 F350/CC/LB/Diesel/Dually/Bilsteins
2013 Cedar Creek 36CKTS/Trail-Air/Pullrite 20.5K Super 5th/TST-507RV
rich and char is offline   Reply With Quote
Old 02-04-2013, 08:06 AM   #12
Were the doors, spot free before the Rainx ? If not how did you clean the over lap areas?
Joe Wakeman
2012 36RE
2013 2500HD Duramax
jwakeman is offline   Reply With Quote
Old 02-04-2013, 01:47 PM   #13
Full Timer
life2short4nofun's Avatar
She is able to fold a towel and slide it in there to clean the water spots off. I will try the rain x. We use a good car wax on the walls. We use a water softener when it warm so we didn't get spots but its been single digits at night were we been so we didn't use it and we have been getting spots.
Ford Western Hauler
2013 CC 36B4
life2short4nofun is offline   Reply With Quote
Old 02-04-2013, 11:02 PM   #14
I use Gel Gloss on the shower stall, it cleans, removes scratches, and has a wax that works like rainx. It is madefor fiberglass! Easy to use!!
Amazon.com: T.R. Industries GG1 Gel Gloss Miscellaneous Bath Accessory: Home Improvement
Larry & Kerry Jackson
2012 Ford F250SD
2013 Columbus 320RS
Kerryj is offline   Reply With Quote
Old 02-16-2013, 04:29 PM   #15
I used lime away to take the first layer off the glass, than applied glass cleaner with rain x. Boy what results. After a week it looks like it is also attacking the lime I could not reach.
Thanks for the info.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
Old 02-17-2013, 09:43 AM   #16
Trailer Trash
Keeping the aluminum slider track on the base clean is my challenge. Can't just shoot water in the track without it spilling all over the floor. Need a small sponge or brush to fit between the tracks is the only thing I found so far.
The walls and door, I use that clear spray bottle shower cleaner stuff while the walls and door are still wet. Tilex is one brand. Got in the habit of wiping glass doors clean/dry after a shower too.
Seem to recall Rain X and plastic don't get along but that may be just for optical reasons. Not for use on plastic windshields.
joelek is offline   Reply With Quote
Old 02-17-2013, 07:39 PM   #17
Earth Station's Avatar
Today, I did the gel-glass on the shower walls and rain-ex on the doors.... We also used a dremel to open the shower rail drains. Lets see how that works.
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 02-17-2013, 09:46 PM   #18
Trailer Trash
Bias your leveling of trailer (left to right) so entry door side is a bit high from center. This also helps water drain out of shower rails. When it is centered or even worse, biased the other way from center, rails wont drain fully.
