Old 02-03-2013, 12:59 AM   #1
rmalikone's Avatar
3 pc glass shower door ?
We have a 2012 CC 36RE and the bathroom has the 3 pc shower door and the wife needs to know if anyone knows how to get to the areas of the shower doors that overlap so she can clean those areas on the doors.
rmalikone is offline   Reply With Quote
Old 02-03-2013, 10:09 AM   #2
We applied RainX to the glass, both on inside and on the outside. NO more waterspots
Torben & Patty
2014 Chevy 3500 HD Duramax 4x4, B&W Hitch
2013 Cedar Creek 30RL Custom Paint Washer & Dryer
torben is offline   Reply With Quote
Old 02-03-2013, 10:09 AM   #3
Fulltime family RVer
No clue- same problem here.
ependydad is online now   Reply With Quote
Old 02-03-2013, 04:36 PM   #4
Rich and Char
rich and char's Avatar
We just ordered our CC 36 CKTS and also have the same shower door. I was asking my husband how was I going to keep that clean. Thanks for the input! I am going to try it!
2011 F350/CC/LB/Diesel/Dually/Bilsteins
2013 Cedar Creek 36CKTS/Trail-Air/Pullrite 20.5K Super 5th/TST-507RV
rich and char is offline   Reply With Quote
Old 02-03-2013, 08:06 PM   #5
KKranec's Avatar
Great idea, I will get some rain x! Thanks for the idea.
KKranec is offline   Reply With Quote
Old 02-03-2013, 08:14 PM   #6
Earth Station's Avatar
X2..... love that idea!!! wonder..... can it be applied to the shower walls??? How often should it be reapplied????
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 02-03-2013, 08:17 PM   #7
Fire Instructor's Avatar
RainX!!! What a great idea! We have the corner installed glass "garden shower", and even with the single piece door, it constantly needs to be cleaned due to the water spots. Have to try the RainX next season!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 02-03-2013, 08:18 PM   #8
KKranec's Avatar
My 36ckts is on order and now I can't remember if it has a 2 or 3 piece door?
Old 02-03-2013, 09:42 PM   #9
Campingnut's Avatar
The 36 has a 3 piece door.
Thanks for the rain x tip.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 02-03-2013, 09:58 PM   #10
Rich and Char
Yes, a 3 piece door.
Old 02-03-2013, 10:13 PM   #11
Rich and Char
I'm not sure if I would apply it to shower walls? But I will tell you that I use that CLR cleaner (bath & kitchen) on our shower wall. It takes away that calcium, lime and hard water deposits. I love it! Just spray on walls, wait about 5 mins, wipe & wash away!
Old 02-04-2013, 09:06 AM   #12
Were the doors, spot free before the Rainx ? If not how did you clean the over lap areas?
Joe Wakeman
2012 36RE
2013 2500HD Duramax
jwakeman is offline   Reply With Quote
Old 02-04-2013, 02:47 PM   #13
Full Timer
life2short4nofun's Avatar
She is able to fold a towel and slide it in there to clean the water spots off. I will try the rain x. We use a good car wax on the walls. We use a water softener when it warm so we didn't get spots but its been single digits at night were we been so we didn't use it and we have been getting spots.
Ford Western Hauler
2013 CC 36B4
life2short4nofun is offline   Reply With Quote
Old 02-05-2013, 12:02 AM   #14
I use Gel Gloss on the shower stall, it cleans, removes scratches, and has a wax that works like rainx. It is madefor fiberglass! Easy to use!!
Amazon.com: T.R. Industries GG1 Gel Gloss Miscellaneous Bath Accessory: Home Improvement
Larry & Kerry Jackson
2012 Ford F250SD
2013 Columbus 320RS
Kerryj is offline   Reply With Quote
Old 02-16-2013, 05:29 PM   #15
I used lime away to take the first layer off the glass, than applied glass cleaner with rain x. Boy what results. After a week it looks like it is also attacking the lime I could not reach.
Thanks for the info.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
Old 02-17-2013, 10:43 AM   #16
Trailer Trash
Keeping the aluminum slider track on the base clean is my challenge. Can't just shoot water in the track without it spilling all over the floor. Need a small sponge or brush to fit between the tracks is the only thing I found so far.
The walls and door, I use that clear spray bottle shower cleaner stuff while the walls and door are still wet. Tilex is one brand. Got in the habit of wiping glass doors clean/dry after a shower too.
Seem to recall Rain X and plastic don't get along but that may be just for optical reasons. Not for use on plastic windshields.
joelek is offline   Reply With Quote
Old 02-17-2013, 08:39 PM   #17
Today, I did the gel-glass on the shower walls and rain-ex on the doors.... We also used a dremel to open the shower rail drains. Lets see how that works.
Old 02-17-2013, 10:46 PM   #18
Trailer Trash
Bias your leveling of trailer (left to right) so entry door side is a bit high from center. This also helps water drain out of shower rails. When it is centered or even worse, biased the other way from center, rails wont drain fully.
