Old 07-03-2013, 02:35 PM   #1
OL Creeker's Avatar
30 amp vs 50 amp power
When we arrive at THE rally, it will be with our CKTS that we pick up later this month - our 1st 5er. I realize only 30amp service will be available. Our CC will have the res fridge. Will I be able to power it and one AC unit simultaneously?
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 07-03-2013, 03:16 PM   #2
Oakman's Avatar
It shouldn't be a problem. Be sure to use propane for the water heater and not electric.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-03-2013, 03:18 PM   #3
Certified Curmudgeon
Not a problem. We can and have run our Whirlpool and the HP main AC on a 15 amp circuit. You may need to cut the A/C off to run the convection/microwave. Ditto on the propane for heating the H2O.
Mike Dropped
Old 07-03-2013, 03:20 PM   #4
chiefly1's Avatar
You should be just fine running the refrigerator and one AC unit on 30 amp. If you run the microwave it might have issues but even that will depend on your model.
chiefly1 is offline   Reply With Quote
Old 07-03-2013, 03:35 PM   #5
OL Creeker's Avatar
I really hope to meet some of you at Goshen. You've answered my questions, helped me along the way - ok, I got picked on a little too - but I've met - though by proxy - a great bunch! Thank you.
Duramax/Allison
Old 07-03-2013, 05:42 PM   #6
Full Timer
life2short4nofun's Avatar
When we are on 30amps we run the 2 refrigerators (residential inside and small apartment one outside), one air, then we pick one other thing; the other air, hot water heater, or the microwave.
Ford Western Hauler
2013 CC 36B4
life2short4nofun is offline   Reply With Quote
Old 07-03-2013, 07:46 PM   #7
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
You'll need a 50A female x 30A male adapter (available @ RV suppliers, Camping World and of course, Walmart) and you will have no problems.
BTW your fridge is powered by the 4 6 volt batteries through the inverter when not plugged into shore (park) power. When you are plugged in to shore power the inverter is in bypass mode, the fridge is powered normally from your AC bus.
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 07-03-2013, 08:32 PM   #8
hkreck's Avatar
I have a 30 amp MH and was told once that I could plug into a 50 amp service with an adapter. I've never tried it and am wondering what the general opinion is about this?
Henry & Tena
hkreck is offline   Reply With Quote
Old 07-03-2013, 08:43 PM   #9
Full Timer
I never have had a 30amp coach but have met several people plugged into 50amp plug with a 30amp coach using the adapter with no problems.
Ford Western Hauler
2013 CC 36B4
Old 07-03-2013, 08:49 PM   #10
hkreck's Avatar
I didn't think there would be but didn't want to do something that could cause damage. I would think it would work better providing more amp's to the rig to run things?
Henry & Tena
Old 07-03-2013, 09:14 PM   #11
That's not how it works. You will only get 30 amps past your RV's main breaker.
Mike Dropped
Old 07-03-2013, 09:16 PM   #12
VinceU's Avatar
Only problem with this is, if the 30A breaker in the RV fails to clear in an overload situ, the shore won't open till over 50 amps is reached. Something will smoke in the meantime. Your cord or your dist panel, just buyer beware.
Old 07-04-2013, 09:12 AM   #13
hkreck's Avatar
OK thanks guys this is what I'm trying to find out before I hook up to one. The forum and youtube are the best places I know to find info. Keep it coming. Happy Independence Day. 4th of July.
Henry & Tena
Old 07-04-2013, 09:48 AM   #14
Love My Sunseeker
DXSMac's Avatar
My question fits the title of this thread. An electrician at an RV park told me that it's ok for 50 amp rigs to use 50/30 dogbones, but those of us on 30 amp should not attempt to plug into 50 amp with 30/50 dogbones. In eight years of RV'ing, I have only encountered two situations where I was at a place that did NOT have 30 amp, or the site I got was 50 amp not 30, or maybe the 30 amp was not working so I plugged into the 50 amp.
The electrician said that using a 30/50 and plugging into a 50, well, you can exceed 30 amp and not know it or something like that.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 07-04-2013, 10:03 AM   #15
I suppose there is the potential to have so many things running in the camper that you would exceed the 30 amp rating of the camper wiring, as the breaker at the pole would not trip. That might result in melted wires, or simply very low voltage to your appliances.
As always, common sense is required.
bakken is offline   Reply With Quote
Old 07-04-2013, 11:29 AM   #16
VinceU already spoke directly to this question in post #12. It is possible IF your 30 Amp main fails. However it is very unlikely. If it is a concern, you can build a buddy box with another 30amp fuse/breaker or a fusible link.
Mike Dropped
Old 07-04-2013, 01:17 PM   #17
outdoor addict
I regularily plug in my MH into 30 amp service. I can power my Norcold fridge, both 13.5K BTU A/C units as well as TV, Blu_ray, etc at the same time. Theone thing I do is that if it is really hot I only start up with one A/C unit ruinning until the unit is cooled down then turn on the 2nd one.
nakerr is offline   Reply With Quote
Old 07-04-2013, 06:41 PM   #18
VinceU's Avatar
See, his 30 amp breaker is maybe a bit too forgiving, what do you expect of a $11.00 circuit breaker? With two in series much better chance of clearing in time. Your xxx,xxx.00 coach depends on it.
Old 07-04-2013, 06:59 PM   #19
If you have a 30 amp RV, then the electric box in your RV has a 30 amp inlet circuit breaker, so it shouldn't matter if you plugged into a 50 MILLION amp plug (I'm being facetious, but you get the idea), you'd still pop the 30 amp RV inlet breaker if you tried to pull more than 30 amps. What you DON'T have when you plug into a higher amp circuit is a backup breaker (the one on the electric post) if your RV breaker fails to open. Actually, you do still have a backup breaker on the post, but it won't open unless you pull 50 amps, by which time your RV could be toast. So you can always plug into a higher amp system (I have many times) but you just need to be aware of the risks.
