Old 12-07-2015, 07:03 PM   #11
I leave my inverter on all the time, what does it hurt
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 12-07-2015, 07:40 PM   #12
dieselguy's Avatar
Actually when left on, the inverter draws a small amount of current from the 12VDC whether supplying 120 VAC or not.
dieselguy is offline   Reply With Quote
Old 12-07-2015, 09:06 PM   #13
There seems to be a lot of confusion about the inverter for the Cedar Creek. The inverter is only connected to the residential refrigerator, period. No other a/c outlets are supplied by the inverter.
The inverter can be left on when connected to shore power. It is drawing minimum current from your battery and your battery will still charge. It will not pop any a/c breakers. It is just in standby mode waiting to sense when the shore power a/c to the fridge goes away. It will switch over in milliseconds if the shore power should go away, say at 2AM when you are sleeping or when you are away from your rig and there is a campground power failure. (not that that ever happens
I generally turn mine on when I pick up the 5ver and then after hooking up to shore power I turn it off with the button on front of the unit. I've also left it on while connected to shore power. It is doing nothing at this point, just in standby. There are status indicators on the front of mine that tell me when 120vac is being used and when it is on battery power supplying the a/c to the fridge.
Just remember if you do turn it off when on shore power to turn it on before you depart your campsite.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 12-07-2015, 09:07 PM   #14
It hurts nothing but the use life of the unit. You are always safe if there is an unexpected power outage...
2016 Siverback 33IK
Old 12-07-2015, 09:12 PM   #15
Kenny kustom's Avatar
So then, with the magnum Hybrid inverter..
It's also a charger. I'm wondering if it needs to be " on" to charge the batteries?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I AM NOT THE WEIGHT POLICE...
2017 Dynamax Isata 4
Old 12-07-2015, 09:40 PM   #16
2016 Sabre 36QBOK
Im sure it does. I just did a little research on the Hybrid Inverter and it is a battery charger when it is in standby mode. When in standby the inverter circuit actually acts as a converter and charges the batteries. When the the shore power on gen power goes away then the batteries stop being charged and supply current to what is now the inverter. It would have to be on I would think to activate the hybrid inverter/converter.
I found this on the web. I don't know if it is your exact unit but there are some nice power flow diagrams on pgs. 30-31
Actually it is a 24v unit but the functionality is the same I'm sure..
http://pdf.wholesalesolar.com/invert...359.1449544835
2016 Siverback 33IK
Old 12-08-2015, 04:15 AM   #17
Rest and Relax's Avatar
Thank you answers my question perfectly.
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
inverter, power
