Old 12-06-2015, 11:37 AM   #1
33IK inverter powers ??
We have the 33IK with residential frig and I am wondering what the inverter powers. Specifically, with the water heater switch set to ON to use the elect element, while traveling is this on the inverter circuit? Or, with it set to ON, will it only be powered when hooked to shore power. Seems it would be a pain to need to turn it on and off outside each time we connect or disconnect from shore power. But, I have not been able to find what exactly is powered by the inverter.
Thanks for the help.
segel10 is offline   Reply With Quote
Old 12-06-2015, 01:05 PM   #2
dieselguy's Avatar
Inverter supplies 110 VAC from battery(s) 12VDC. Inverter powers fridge when off shore power ... that's it. Battery powers 12VDC lights, radio, CO2 detector, level up, fridge control board, heater fan, and solenoids, water pump. Shore power does electric side of hot water heater, TVs, microwave, AC outlets, A/C's, ceiling fan, and converter.
dieselguy is offline   Reply With Quote
Old 12-06-2015, 01:14 PM   #3
Thanks dieselguy!
Old 12-07-2015, 07:57 AM   #4
wls
I have a question also. So when traveling down the road hooked up, turn the inverter on? When hooked to shore power, turn it off?
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 12-07-2015, 09:33 AM   #5
Jim34RL's Avatar
Yes,
The inverter is not required to operate the fridge when you are on shore power.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 117K+miles
Old 12-07-2015, 10:09 AM   #6
Busybeavers's Avatar
When traveling down the road, Yes, turn on the inverter that way your frig will be operating off the batteries and your tow vehicle. When you hook up to shore power, turn off the inverter. Note: you must turn off the inverter or your batteries will not charge.
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Busybeavers is offline   Reply With Quote
Old 12-07-2015, 11:20 AM   #7
wls
sorry for sort of robbing this thread, but I thought it may help the OP. Thanks for all the info.
Also wanted to mention, on my coach, the inverter is for my fridge only.
Old 12-07-2015, 02:15 PM   #8
Medic97's Avatar
Just a word of warning. Make sure the inverter is off when hooked to shore power. You will not like popping all your breakers.
Robert & Wendy M
5er: 2016 Columbus 320RS - TV: 2015 F250 6.7L V8 Diesel
Part-timer; Looking forward to fulltime...
Medic97 is offline   Reply With Quote
Old 12-07-2015, 04:44 PM   #9
Rest and Relax's Avatar
I just picked up my tlr 38fb2 and have yet to use it but my dealer told me the inverter had to be on for the fridge to work, should I believe him or is he misinformed on the matter (confused)?
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
Old 12-07-2015, 04:54 PM   #10
Kenny kustom's Avatar
When plugged in, the shore power should pass though the inverter.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I AM NOT THE WEIGHT POLICE...
2017 Dynamax Isata 4
inverter, power
