Old 06-21-2019, 11:56 AM   #1
34IK
New member with a 34IK not even 30 days old. Just curious with other owners. Wife went to use the vacuum this am and the only way to turn it on is go outside and turn in on in the storage compartment. Found this kind of strange you cannot turn it on inside if you want to use the hose. Al
BigAl52 is offline   Reply With Quote
Old 06-21-2019, 01:53 PM   #2
Make sure the hose is fully seated in the suck port. We had to wiggle ours a little one time.
Does the floor duster go on when you lift the door. If not, you may have a remote power problem
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 06-21-2019, 04:19 PM   #3
Floor duster works like a champ. No trouble with the hose at all. Just found it kind of strange you gotta go outside to turn on the vacuum. Looked underneath to see if it was plugged into an outlet by chance but appears to be wired direct. Al
Old 06-21-2019, 05:18 PM   #4
You don't on mine. 2 separate switces. The On/off outside and the auto on inside when you plug in the hose.
Cathy & Jeff
Midland, Michigan
Old 06-21-2019, 07:08 PM   #5
Ok thanks for the tip. My wife was at this detail and I just went and tried it for myself. You gotta put a little more muscle in to the hose. When I did that she fired right up. Al
Old 06-23-2019, 07:32 AM   #6
Stupid Lucky
Enjoy your 34ik, we are loving ours!
Sandbagger is offline   Reply With Quote
Old 06-29-2019, 10:59 AM   #7
Yup beautiful Coach!
MikeRP is offline   Reply With Quote
