Old 05-26-2019, 01:30 PM   #1
34IK cable reception
I have a 2020 34IK. TV works great on OTA set up.
With amp off and cable connected I get nothing. Jensen manual says I need a settop box. Not buying that. I've tried at 3 different CG's with same result.
Have not tried connecting directly to TV yet.
Need some help.
TCrossan
2020 CC Hathaway 34IK, 2012 F350
tcrossan is offline   Reply With Quote
Old 05-26-2019, 01:31 PM   #2
BandJCarm's Avatar
Need some help.
What cable? Connected to what?
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-26-2019, 01:49 PM   #3
rracer5's Avatar
Need some help.
Nope! Not if the CG offers free cable WITHOUT HAVING TO SUPPLY YOU WITH A BOX. If they say "just hook up your coax cable" and you still get nothing then there are several things you'll need to check/repair.
1 - Did you go through the Tv's source menu and choose "cable" then perform a channel scan?
2 - Like you said, try connecting directly to the Tv first, channel scan, then..
3 - Sometimes, the brilliant tech at the assembly plant mis-labels the cable inputs. You may actually be connected to the satellite input. Try switching the cable to the other.
4 - You may also have to find any splitters installed at the factory and check for tight connections and good crimps on those connectors. All the connectors for that matter.
Good luck.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
cable, reception
