Old 09-29-2019, 11:43 AM   #1
mshenygo's Avatar
34IK slide binding up
Just got home from long weekend camping trip locally, got home unhooked auto leveled and went to open the slides up bedroom slide opened no problem main slide with the recliners and dinette started to open then made some nasty noise and barely opened took a look and seen it opened a little bit on the right side( if you outside looking at the slide) left side never opened. As you can see from the picture it really scraped.also the bottom of the slide on the outside is to closed fully. We have a another trip booked in 2 weeks, I am sure the dealer will not be able to get us in before that. Any ideas???? Thank youClick image for larger version
ID:	216070Click image for larger version
ID:	216071Click image for larger version
mshenygo is offline   Reply With Quote
Old 09-29-2019, 01:31 PM   #2
mshenygo's Avatar
Well upon further investigation here is what I found, broken teeth off of the gear. Has anyone ever had this happen? Wow not sure if this is a major problem.Click image for larger version
Old 09-29-2019, 07:38 PM   #3
Daycruiser's Avatar
You might be able to get a mobile tech to look at it in the time frame you're dealing with. Otherwise you're RV really needs to go to Topeka IN, Orvan Fry's shop to be repaired properly.
44 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 09-29-2019, 08:11 PM   #4
Check with etrailer... they can probably send you a new gear pack. Check this out and call them, they can be helpful
2016 Siverback 33IK
Old 09-29-2019, 09:05 PM   #5
mshenygo's Avatar
So how do you find out how to get it in there? Since it is only a month old.
Old 09-29-2019, 09:29 PM   #6
Orvan is probably booked longer than your dealers wait time. You can buy the gear. If you canít handle the repair job call a mobile tech. Call FR and have them recommend one.
2016 Siverback 33IK
Old 09-29-2019, 09:59 PM   #7
What cause the teeth to break like that?
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
grumpyer is offline   Reply With Quote
Old 09-30-2019, 05:26 AM   #8
mshenygo's Avatar
This slide always made noise going out from the day we picked it up a month ago, I am guessing something was never setup or adjusted correctly from factory. Just my 2 cents. I am contacting my dealer today and also emailed forest river.
Old 09-30-2019, 10:22 AM   #9
mshenygo's Avatar
Update
Got a hold of dealer and told me to bring it right in he may have the gears in stock so hopefully it will be quick turnaround and fixed correctly. Also cedar creek emailed me back and said they will get things on their end rolling so this can get resolved quickly. So I am hopeful it will. I will follow up on here.
Old 09-30-2019, 12:09 PM   #10
Broken slide??
This exact thing happened to us in Lawrence, KS. Called mobile tech who was able to machine a new gear case AND was able to find a gear that was much more durable and forged, not cast from cheap metal like the gears that come on the rig. Repair cost us $950 but was totally reimbursed from FR. The original gear is pretty cheap so we ordered two extras...just in case.
Oneiron is offline   Reply With Quote
Old 09-30-2019, 03:49 PM   #11
ronzo101's Avatar
Slide Gears
This is more informational but after I replaced my gears, the slide would still skip on the initial problem side. I found this "fix": http://www.rvupgradestore.com/v/vspf...s/pdf/0065.pdf
(Sorry don't know why I can't rotate the pictures)
ID:	216292   Click image for larger version
ID:	216293   Click image for larger version
Ron & Donna
Cape Cod, MA
Retired Firefighter/EMT
2014 Flagstaff 27RLWS
2008 GMC Sierra 1500 SLT
ronzo101 is offline   Reply With Quote
Old 09-30-2019, 05:58 PM   #12
mshenygo's Avatar
Thanks for the info very much appreciated. We just dropped the rig off at the dealer so I will see how things go when we get it back. I will keep this updated.
Old 09-30-2019, 06:43 PM   #13
mshenygo's Avatar
Have you had any problems since and does the slide work smoother now?
Old 09-30-2019, 06:46 PM   #14
mshenygo's Avatar
Did you do it yourself and does the slide need to be timed or synchronized?
slide
