Old 05-16-2015, 10:26 AM   #1
Mark and Becky's Avatar
34RLSA Spare Tire
Just came back from a trip and while preparing to back in, I noticed the spare tire hanging / swinging under the trailer. I haven't crawled under there yet as we have had heavy rains, but is there something I should be looking for to get the tire stowed again? Up until now, I've never had to do anything with this tire.
Mark and Becky is offline   Reply With Quote
Old 05-16-2015, 03:11 PM   #2
ret2006's Avatar
Should be able to crank it back up using the crank handle you should have somewhere in your basement. It is extended or retracted by cranking the rod under the right slide. You will probably have to extend the slide or use a ratchet. The tire is hanging on a cable attached to the center of the tire rim, it is cranked up and down on a spool. It must have backed off some way.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 05-16-2015, 09:07 PM   #3
Great call. Found the wrench and cranked it back into place! Thanks for your help.
-Mark
Old 05-21-2015, 07:33 AM   #4
dieselguy's Avatar
Several of us that have the underbelly tire carriers add a ratchet strap around the tire and carrier frame. It adds peace of mind and prevents the winch from unwinding like yours did. A bouncing tire at 60 mph gets peoples attention on the road.
dieselguy is offline   Reply With Quote
Old 05-21-2015, 08:50 PM   #5
Great idea. I'll give it a try.
tire
