Old 07-08-2016, 05:39 PM   #11
97flhtcui's Avatar
GRV Ba15s 1156 1141 High Power Car LED Bulb 102-3528 SMD DC 12V Super Bright Cool White Pack of 2
These are the LEDs I installed on the outside for the porch, and scare lites.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
97flhtcui is offline   Reply With Quote
Old 07-09-2016, 08:47 AM   #12
GDoubleU's Avatar
LED
I googled LED bulbs and ordered all of mine thru the net. They were alot cheaper, but they took alot longer to receive from overseas. Watch out for the pins on the side, there are two types and I had to have different ones for the light above the table.
GDoubleU is offline   Reply With Quote
Old 07-09-2016, 10:06 AM   #13
I ordered from Amazon last night. Along with the interior bulb replacements I bought a 5 pack for the 1156 replacements for outside. Can someone confirm the quantity I'll need? I am away from my trailer.
Doug & Cindy
2014 36 CKTS: Titan Disc Brakes, EMS, Trav'lr, 20k GooseBox
2016 Ram 3500 CTD 4x4 CCLB DRW, Laramie, Factory Rear Air Suspension, 3.73
DJNCJ is offline   Reply With Quote
Old 07-09-2016, 10:12 PM   #14
GDoubleU's Avatar
I have a 2017 Hemisphere and needed 32 on the inside.
Old 07-11-2016, 11:01 AM   #15
Same problem very early on my 2013 CKTS. Finally got all 3 out by just working patiently but broke one of the receptacles in the fixture. Was at the FROG Rally and had it on my "fix list". They had discontinued that fixture but searched the factory and came up with a match. Be sure to note the length of the stem of the fixture if you are lucky enough to find replacements. All 3 are different. When replacing the bulbs I lubed them up with Vasoline and that seems to have done the trick for future removal. I found LED's all over the web but just make sure you have the proper base. Some bulbs may not work at first but just turn it 180 degrees in the base and it will.
Jordyn is offline   Reply With Quote
Old 07-12-2016, 09:51 AM   #16
Double contact with the two side posts directly across from each other.
light
