Old 07-07-2016, 02:54 PM   #1
36 CKTS Pendant Lighting
I have a 2013 36 CKTS with three hinged pendant lights over the island. I have two issues. First, when attempting to replace a burned out bulb in one light, I broke the receptacle the bulb fits into. Does anyone know the light brand or how I might get a replacement receptacle? Secondly, I would like change the automotive type bulbs to LED and I'm not sure how to accomplish this. Any help would be appreciated.
Steve & Lee
Jacksonville, FL
2013 Cedar Creek 36 CKTS Touring Edition
2012 F350 King Ranch, Reese Elite 18 and Air Bags
Elkrun is offline   Reply With Quote
Old 07-07-2016, 06:25 PM   #2
I have the same problem with mine. I'll keep looking on this thread
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 07-08-2016, 08:20 AM   #3
Me too. I want to switch them out to LED's.
Last weekend I tried to remove a bulb to see what I had so I could look for an LED replacement but could not. I pushed, pulled and twisted but stopped because I felt something was about to break.
Additionally the bulbs in the fixture above the table are slated to go to LED's. They pull straight out. I would like to know what to use as an LED replacement for them... Anyone know?
Doug & Cindy
2014 36 CKTS: Titan Disc Brakes, EMS, Trav'lr
2016 Ram 3500 CTD 4x4 CCLB DRW: Andersen Alum II, Factory Rear Air Suspension, 3.73
DJNCJ is offline   Reply With Quote
Old 07-08-2016, 08:45 AM   #4
Mine is led but like you say I can't get them out
Old 07-08-2016, 10:06 AM   #5
switch to led
The ones above the island are twist and pull. They are very hard to get out.
Don't remember the number.
The ones above the table and ceiling lights are push/pull.
That # is 921.
This is where I got my LEDS from M4products.com
You get a discount if you use discount code rvgeeks5
C.B.
cbvp is offline   Reply With Quote
Old 07-08-2016, 10:18 AM   #6
Thanks for the info C.B.!
A quick look at their web site reveals thet all I need to know (for the three pendant lights above the island) is if they are single center contact or double. I presume single but would like confirmation as I am away from my trailer.
Doug & Cindy
Old 07-08-2016, 01:07 PM   #7
DJNCJ,
The lights above the island are two contact and are 1076 automotive style...........very hard to find. The reason the bulbs are hard to remove is the lead contacts on the bulb stick up too high above the base and the receptacle is not spring loaded. Once the bulbs are forced in the heat of the incandescent bulbs almost welds the contacts together. When I replaced a couple of the bulbs I used a file to knock down the bulb contacts so they would be easier to install and replace. Unfortunately, that is how one of the receptacles was broken.....the bulb would not easily come out.
Steve & Lee
Jacksonville, FL
Old 07-08-2016, 03:51 PM   #8
edt
Been there and done that all parts are available from Amazon .I only replaced the broken one e mail me if you want a list of the parts. Edwardt6@gmail.com
North Ga
2015 40' cls
Never to be moved
edt is offline   Reply With Quote
Old 07-08-2016, 06:34 PM   #9
97flhtcui's Avatar
GRV Ba15d 1076 1142 High Bright Car LED Bulb 102-3528 SMD DC12V Cool White Pack of 2
These are the LEDs I bought from Amazon above the island. The 1076's got stuck when they burned out so I put LEDs in.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
97flhtcui is offline   Reply With Quote
Old 07-08-2016, 06:36 PM   #10
97flhtcui's Avatar
GRV T10 Wedge 921 194 30-5050 SMD LED Bulb Lamp Super Bright Cool White Dc 12v Pack of 2
These are the LEDs I put above the dining table.
light
