Old 07-08-2013, 01:44 PM   #1
36ckts furnace temp
Anyone with 36CKTS have an issue with the temperature of their heated air being WAY too hot ie: hot enough to burn your foot on the register in the bathroom?
2017 RAM 3500 DRW CC Laramie, Curt Q20
2013 CC 36CKTS
Me and DW
2 cats: Bello & Dexter (Peanut) RIP
DavandJane1 is offline   Reply With Quote
Old 07-08-2013, 02:46 PM   #2
TURBS's Avatar
The ones I have get quite warm nearest the furnace.
Replace the metal one with a plastic one.
Shouldn't you be asking a/c questions?
Old 07-08-2013, 05:47 PM   #3
Former Full Timer
Duckogram's Avatar
It does get very toasty however we have only run our furnace twice for 15 minutes at a crack when the OAT was a frigid 40*.
We did have the burn issue in our 03 Legacy so I cut a chunk of the thick green
filter material and stuck it in the bottom of the vent then safety wired it in. It reduced the air flow enough to keep from burning and kept all the "stuff" my DW dropped from going into the duct as an added benefit. You can get the green stuff at Home Despot for a few bucks per sheet which is enough for 10 vents.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 07-08-2013, 07:52 PM   #4
Fixing isn't a problem. Since I have diabetic neuropothy I managed to get
3rd degree burns on 3 of the toes on my left foot. Just wondered if anyone else had the same problem.
2013 CC 36CKTS
Me and DW
Old 07-08-2013, 08:48 PM   #5
VinceU's Avatar
No, but wood slat registers don't conduct heat like metal and plastic. Avail in most popular sizes.
Old 07-08-2013, 09:12 PM   #6
Former Full Timer
Duckogram's Avatar
Yes. With our type of furnace when you put a vent a few feet up stream from the burner it gets way to hot.
