That looks marvelous. In addition to the fine work you already did, if you want to make it easier to access the closet you can remove the left door, flip it over and attach it to the right door with a full length piano hinge. You will need to relocate the left closer tongue to the top and add a stabilizer to the bottom left to relieve the stress from the right hinges. I used a hard rubber door knob stop cut in half and beveled to glide up on the bottom of the frame. Made access a breeze. Just a thought.
Mike Dropped
