Old 09-11-2016, 02:54 PM   #1
kinzoo's Avatar
36CKTS refrigerator upper vent
(2013) 36CKTS -upper fridge vent has a piece of plywood across the vent.
Has anyone noticed this on there're RV's.
Do think this would keep the fridge from cooling properly??
Came from the factory this way.
Should I cut it out????
kinzoo is offline   Reply With Quote
Old 09-11-2016, 05:36 PM   #2
Steelchef
cobatoma's Avatar
Ditto
My 38CK has the same - plywood covering the vent. Would sure appreciate hearing from some of you who are 'in the know.'
Home base - 2014 Cedar Creek 38CK (full load.)
Travel wagon - 1994 Phoenix/Cobra 34' motor home.
Toad - 2000 Suzuki GV.
PV - 2012 Toyota Rav 4
cobatoma is offline   Reply With Quote
Old 09-11-2016, 06:06 PM   #3
SnP
Both Cedar Creek techs and Dometic techs told me that it is to draw/force the air over the fins before exhausting out the top vent. My 2015 34RLSA is built the same.
Steve and Paula
Tiki (Our Papillon Kid) RIP Chance
2015 Ford F-350 Platinum DRW, 6.7L, 4x4, TS3 hitch
2015 Cedar Creek 34RLSA-7, fully loaded
Nights camped - 2014-47, 2015-104, 2016-97
FROG membership #OR-0025-223
SnP is offline   Reply With Quote
Old 09-11-2016, 06:13 PM   #4
kinzoo's Avatar
I sent an email to Cedar Creek, hope to get an answer....
Old 09-11-2016, 06:18 PM   #5
Cut the plywood and put two computer fans just above the burner below to force air across the entire back of the frig. I would also put some screen wire on both upper and lower covers to keep varmints (mud daubers) out.
Old 09-11-2016, 08:19 PM   #6
Steelchef
cobatoma's Avatar
Thanks for all comments and suggestions. Old Coot, your idea sounds like the best plan. Will see if CC will pony up as the unit is not getting enough cooling at ambient temps over about 80F. On highest setting, it runs at about 38-45 deg. Freezer won't keep ice cream cold. Normally sits at 34 and freezes well. It's also intermittent which is why the cooling unit is being replaced. It's 68F now and working perfectly. Thanks for the suggestion. I'll do it, no matter who pays.
Old 09-12-2016, 08:19 AM   #7
kinzoo's Avatar
Reply from CC
Kelly Ware <kware@forestriverinc.com>
7:53 AM (24 minutes ago)
Mr. K,
Thank you for contacting Cedar Creek Customer Service. This was how we used to direct airflow behind the Dometic refrigerators. It is as a design.
We appreciate the opportunity to assist you with your Cedar Creek product.
Thank You,
Kelly
Kelly Ware
Customer Service Advisor
Cedar Creek
Forest River, Inc
Office: 260-593-4000
E-Fax: 574-343-5906
Email: kware@forestriverinc.com
Old 09-12-2016, 09:04 AM   #8
TURBS's Avatar
Like this.
ID:	119993Click image for larger version
ID:	119994Click image for larger version
ID:	119995Click image for larger version
Old 09-12-2016, 10:43 AM   #9
Steelchef
cobatoma's Avatar
Mr. K,
I don't understand this reply. Was there an attachment?
Old 09-12-2016, 10:51 AM   #10
kinzoo's Avatar
No attachment, just this statement:
Mr. K,
Thank You,
Kelly
Kelly Ware
Cedar Creek
Forest River, Inc
E-Fax: 574-343-5906
fridge, vent
