Old 04-09-2012, 10:55 PM   #1
36RE outside TV connection
I have a TV connection related question. On the outside where the TV mounts there are 3 connectors, 1 being a 12 volt outlet, a screw on connector which I hooked to the TV and it have me satellite. The 3rd jack is labeled cable but looks like a female RCA jack. Not threaded and a lot bigger center hole than cable connectors have. Can anyone tell me what this connector is. Thanks. Steve
sdagro is offline   Reply With Quote
Old 04-11-2012, 11:15 PM   #2
Does anyone know what I am referring too? I know someone out there has a 2012 Cedar Creek with the outdoor TV hook-up. Steve
Old 04-12-2012, 06:44 AM   #3
Oakman's Avatar
You're not getting much of a response to this question. Sorry. I don't have your setup but I would guess that if that third connection is label cable, then it is for the cable/antenna signal. If it is not that, then perhaps it is a feed from the DVD player.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-12-2012, 06:47 AM   #4
Herk7769's Avatar
Believe me a photo will help here.
Most likely no one knew what you were tanking about.
Here is my outside connection.
Name:	CBL and SAT inputs.jpg
HAM CALLSIGN - KC3FFW
Old 04-12-2012, 11:20 AM   #5
textman's Avatar
I have the same setup on my Cedar Creek. I will look at mine tonight and see if I can figure out where this RCA jack goes to. From the back of the TV in the bedroom I am not seeing and RCA video out... Curious too as to what this is for.
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 04-13-2012, 09:02 AM   #6
textman's Avatar
Have not tried it to be sure, but I think the RCA jack you are seeing runs from the entertainment system. In my case the Jensen AWM970 in the bedroom. Going to assume this is how you would get your video to the outside TV if you are watching a DVD or utilizing the USB port. I'll will have to test it out this weekend....
Loving Life
Old 04-13-2012, 11:42 AM   #7
Sounds like that may be it. Now why didn't I think of that. Will try it later too. Thanks, Steve
