10-23-2016, 10:37 AM
Mddle of the Rd Extremist
38 FL Battery Servicing
I can't be the first one to have run into this, but I haven't been able to find a thread on the subject. Given the unfriendly placement of the 38FL batteries, it is impossible to check the fluids in 3 of the four batteries, short of removing them, checking the fluid and re-installing all four. Thinking of installing the FLOW RITE system and would like to solicit some comments on it from those with experience.....
Thanks!
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
10-23-2016, 11:04 AM
I worked on a 2006 Monaco Knight with this system on the coach batteries, Owner says he would never have a coach without it. Very easy to use and no guessing or spilling water.
Retired Navy
2016 Flagstaff 26 FKWS
10-23-2016, 11:06 AM
Well it could be worse...being up in the Great White North I think most of us need to pull our batteries, check the levels and give them a charge no and again!
Agree with you the placement of these are not in a friendly place!
Same can be said for the tank for fluid for the levelling system...
Truck 2013 GMC 3500 SLT HD Dully ,Ext.Cab,air bags.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc .tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
[B]Camping Day's: Never Enough
10-23-2016, 11:40 AM
I have used the pro fill system for my 4 - 6 volt batteries. Like you have said it is hard to see the fill line on the batteries. With the pro fill system you just pump until the bulb is firm. I have been very pleased with this and have used it for almost 2 years.
10-23-2016, 12:29 PM
Totally agree. I hate this time of year. It is a real PITAS to get the batteries out and then again in the spring to replace them but I don't want them to be left in the rig and die due to the cold. It really is trial by touch trying to get them out - barely no space, even for fingers.
Richard & Diane
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
10-23-2016, 08:21 PM
I installed the Flow Rite Watering System shortly after taking delivery of our 36CKTS in April. There was no way to check the water level on the 4 batteries in that cramped space. So far I'm happy with the system.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
10-23-2016, 08:38 PM
I use the flow rite system for my four batteries in my 36ckts and it seems to work like a charm. That being said, i am just assuming everything is working properly and all of the cells are filled to the proper level because i am still too lazy to take them out and physically check. The batteries are holding up fine though.
10-23-2016, 11:28 PM
I took all 4 of my 6 volts out to check the water level just after I bought it. None of them was filled to the right level. Those bad boys are a handful to wrestle in and out. I may have to check into this.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
10-24-2016, 06:34 AM
I moved the batteries over so I could get at them. I also used the auto watering system. just no room for the batteries .
