Old 07-20-2014, 12:55 PM   #1
38FL water pressure from the pump
Hi All,
We keep our 38FL at our lake property full time and only run off of the fresh water tank and pump. ( sure wish we had a gravity fill like all of our previous units ) We are experiencing lower than usual water pressure at all outlets. Is there a filter screen on the pump that I need to go digging for?
Thanks in advance,
Don
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 07-20-2014, 08:10 PM   #2
You have two filters - the whole unit filter in the docking station (which you probably already know) and a particulate filter/strainer on the pump itself. It only filters large debris - pump is located behind the panel right behind the docking station. One the end of the pump there is a clear housing - twists off.
Amazon.com: SHURflo 255-313 Classic Series Twist-On Strainer (1/2" FPT x 1/2" ): Automotive
On new units this will clog with plastic pieces from the tank.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 07-21-2014, 08:46 AM   #3
Thanks Walter.
You always have good information. Looks like this upcoming weekend I will be working my way through the maze of wires, water lines and hydraulics. UGH! They couldn't place that water pump anywhere more accessible?
Thanks again,
Don
Don and Michele
Old 07-21-2014, 07:20 PM   #4
kc8lvy's Avatar
I bought a small 12 volt water pump from Harbor Freight and use 6 gal water jugs. Fills easy and fast..
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 07-21-2014, 11:56 PM   #5
I have access to water to fill the tank, but I have to run about 200' of hose. Fortunately I don't need to refill too often. I just feel a higher end unit like the 38FL should have had a gravity fill like ALL of my other RV's.
I may try Walter's idea of using the antifreeze fill and sprayer. I draw from the antifreeze in a 5 gallon bucket for the use of the toilet during winter months.
Don
Don and Michele
Old 07-26-2014, 06:01 PM   #6
Well, I took the filter screen at the pump apart and it was totally clean. Pulled the screen off of the kitchen faucet and it was almost as clean as the pump screen. Looks like the pump is sub par and I'll be looking for a replacement unit. Fortunately we have access to a bath house so we don't need to shower in the RV.
Thanks for the input,
Don
Don and Michele
pressure, pump, water
