04-05-2015, 10:01 AM
Mddle of the Rd Extremist
38FL Window Screens
DW wants me to remove the screens so she can clean the inside of the windows. Unfortunately, all the little tabs are on the OUTSIDE of the screen and there's not enough space between the screen, the mechanism and the window to get up in there to pull on the tabs. Almost seems that the screens are installed with the "inside out"......Any help? Thanks
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
04-07-2015, 07:16 PM
The fact that this hasn't merited even ONE reply tells me that it must be a really stupid question and that the answer must be staring me in the face???? Or is this a problem unique to MY 38fl?
MCPO (Retired)
04-07-2015, 07:31 PM
Most probably like me have never taken the screen out to clean windows so I know I have never done that. Next time I am in the RV I will have to look them.
Tom & Marilyn
2013 Chevrolet Duramax 3500 HD LTZ Crew Cab Long Bed Z71 4X4
2015 Cedar Creek 38RD Hathaway Edition
04-07-2015, 07:40 PM
I actually noticed that last year. I use a small screw driver to pull the screens into the rig so we can clean windows. I actually assumed those tabs put pressure and hold them in and were not really for removing them.
Walter
The only dumb questions are the questions not asked....
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
04-07-2015, 07:49 PM
Normally there are spring clips that are depressed by pushing the frame against them and then pulling the tab.
04-08-2015, 11:06 AM
Walter
Walter - tried the screwdriver idea. I started with the kitchen window, as it was the one that needed cleaning most. Got it popped loose but could not remove the screen because, no matter from which direction I tried to slide it out, there was not enough room to get it past the water faucet or cabinets to either side. It looks like the screen was installed before the faucet.....back to the drawing board
Dan
MCPO (Retired)
04-08-2015, 11:13 AM
I removed all the screens in my XLR to clean them after about a year. They were the same as yours, with the clips on the inside. It wasn't much of a problem and I don't recall breaking any of them. Once you get one clip to release, the rest come easy.
On my Silverback, I have the same screens but haven't removed them for cleaning yet. I do use wet paper towels to wipe the dust off the screens where I can get to them.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
04-08-2015, 11:22 AM
Dan,
I am guessing you have a different (newer) style window. The screen comes out very easily on ours.
Walter & Donna
04-08-2015, 03:05 PM
You're totally correct. I do have different windows......probably need to resort to one of those microfiber triangles on a stick things.. Thanks for sharing
MCPO (Retired)
06-13-2015, 08:00 PM
Have 38RD - pulled screen in Kitchen to clean off cottonwood - can't get it back in to save my ass - anyone know the trick to reinstalling these? Grateful for any suggestions.
06-13-2015, 08:51 PM
My 37ft, 2015 Silverback has these windows. Push that shade all the way to the top, take a drink of whiskey, try every angle and PATIENCE ! They are difficult but you will prevail! I had to remove 2 screens when I had satellite
Issues and fed a cable direct to the TV. Send family away! It is permissible to use bad language!!
Here is a FUTURE TIP... Place a mark or removable tape in one corner of the screen, like upper right, so you know you are in the correct pattern to install it. Helps( a lot )
