Old 07-16-2016, 02:27 PM   #31
I think you have a lot more engineering skills than the people that designed the setup we currently have. Not sure I'm going to mess with it any more. Will just use my small bunge cords and live with it until we can afford to get something else. I don't think it will be a Forest River product. Having problem with outside light over the door and the step light. Both stopped working at same time so thought the switch was bad. Pulled the panel and got the switch out. It seemed to test ok - so put a new bulb in the above door light - it came on even though I still had the switch out laying on the table??? Put switch back in and it operated the door light - step light was still not working. Pulled that bulb and went to check for voltage - as soon as the probes touched the contacts the door light went out and won't come back on - it's still a good bulb. Now scratching my head again.
justbob is online now   Reply With Quote
Old 07-16-2016, 03:21 PM   #32
ttanous's Avatar
38RD Dining Room Slide Under Belly
Sounds good Justbob.
ttanous is offline   Reply With Quote
roo, slide
