Old 11-25-2013, 08:37 AM   #11
30-amp is much easier than 50-amp.
I think going with the portable is a good choice.
Old 11-25-2013, 09:02 AM   #12
bend302's Avatar
I have the PI 50 amp portable. It is a simple surge only protector. I should have bought one that protects against low voltage as that seems to be more common than surges.
Last year in FL, my neighbors heat pump failed and she had the same unit that I do. The tech told her it could have been low voltage.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 11-25-2013, 09:19 AM   #13
bsmall's Avatar
Originally Posted by spock123 View Post
I just talked to Camping World and the $29 install is really not true, you have to read the fine print. I was told that was not covered under the $29 fee and it would be 2 hours at $120 per hour plus parts. I am thinking now about the portable one now, I don't need to try to wire the unit up myself, I might kill myself or melt the camper.
My trailer is presently at Camping World, getting my axles, and brakes serviced and having the in-line surge protector installed. The install is costing me $29.00.
http://www.campingworld.com/shopping...ge-guard/69522
I do have a question for those of you that have this type of in-line surge protector. Running a Honda generator (EU2000i) will it shut down power to trailer when the generator cycles from idle to full power while using appliances???
I hope this question makes sense.
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 11-25-2013, 10:38 AM   #14
rskrbina's Avatar
I believe the surge protectors are designed to handle up to 132 volts for 8 seconds before they will shut down. I think you'll be ok.
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
rskrbina is offline   Reply With Quote
Old 11-25-2013, 12:37 PM   #15
We have a Honda EU2000i and a Progressive 50 amp EMS and it works fine when the generator load jumps from appliances being cycled.
You do need to use a ground neutral adapter on the Honda or the Progressive EMS will not work with the Honda generators.
2014 CC 34RLSA
2013 RAM 3500 Laramie CC SB 4x4 CTD
sidney is offline   Reply With Quote
Old 11-25-2013, 01:25 PM   #16
rskrbina's Avatar
Sidney
I have a Champion 4000W gen and a (hard wired) Progressive 30 amp EMS. Will I need to use a ground neutral adapter as well?
Rudy and Jenny
Old 11-25-2013, 01:28 PM   #17
TURBS's Avatar
Originally Posted by rskrbina View Post
Sidney
Yes!
And you can make it yourself.
Buy a male plug in at hardware store.
Run a short wire from ground terminal. "Green" screw to the neutral screw "silver".
The "hot" one is gold colored, leave it blank.
Turbs
Old 11-25-2013, 01:47 PM   #18
Sidney
I don't know about the Champion gennies.
But any generator that is not wired ground neutral would require the adapter to work with the Progressive EMS.
As Turbs mentioned the adapters are very simple to make.
2014 CC 34RLSA
Old 11-25-2013, 04:38 PM   #19
HONDAMAN174's Avatar
Originally Posted by f1100turbo View Post
Yes! And you can make it yourself. Buy a male plug in at hardware store. Run a short wire from ground terminal. "Green" screw to the neutral screw "silver". The "hot" one is gold colored, leave it blank. Turbs
Turbs- where do you plug in said adapter? I just ordered a PI EMS30 for my new Evo 2850 and run a Honda 2000.
Just glad to get away
Old 11-25-2013, 04:39 PM   #20
rattleNsmoke's Avatar
Or just shut off the EMS when on the generator? Is there still a real need fo the EMS when on a genny? Inquiring minds wanna know.
rattleNsmoke is offline   Reply With Quote
50 amp
