Old 03-11-2016, 11:40 AM   #41
nosaint3
hitches
have used hensley since 2006 at 300lbs weight and 20000lbs with two airbags.
love it. Fulltimer so I never attempt to take it out. over $3000
nosaint3 is offline   Reply With Quote
Old 03-11-2016, 06:59 PM   #42
Originally Posted by DKRITTER View Post
Little John, we also have the Reese Goose Box and have grown to really like it. It is an approved hitch for CC trailers and replaces the pinbox on the front of the trailer.
How is chucking with the Goose Box compared with the 5th wheel hitches?
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 03-11-2016, 08:18 PM   #43
DKRITTER's Avatar
Sorry Joe, this is our first 5th wheel and therefore I don't have a reference for you.
I can say the ride pulling a 15K 5'r is very easy and stepping up from a TT has been a night and day difference.
2015 Ford F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKRITTER is online now   Reply With Quote
Old 03-12-2016, 06:45 AM   #44
Yup. Pulling a 5er is a lot better than a bumper pull. Some roads cause "chucking" which is the truck and 5er bouncing at a different frequency and feels like the truck and 5er are having a tug of war.
Good luck and safe travels with your new 5th wheel!
Old 03-12-2016, 04:35 PM   #45
Thanks to everyone for the great replies and info!
Rightly or wrongly just dropped off our truck and will be picking it up next week(Tuesday,if we don't get the snow they are talking about) with a Pullrite system!
Take care and be well!
LJ
Truck 2009 GMC 2500 HD,D/A,Ext.Cab,SB,air bags, lift kit, flow gate, etc.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
Camping Day's: 2012:25,2013:27,2014:38,2015:38
Little John is offline   Reply With Quote
Old 03-12-2016, 07:01 PM   #46
Another vote for B&W.
Sierra360PDEK is offline   Reply With Quote
Old 03-12-2016, 07:16 PM   #47
Ford Idaho's Avatar
LJ
What I bought BEFORE I found out about B&W.
Old 03-14-2016, 08:17 AM   #48
Consider the PIN BOX. I have had 2 fifth wheels, cross all road conditions. One a standard pinbox; chucking, bouncing and stuff in rv jarring all over. New fifth wheel; 37ft, has best TRAIL AIR, with inflatable cushion. Thousands of miles. NOTHING MOVES. NOTHING. BOTH RV's using same Curt hitch and SAME TRUCK. Both rv's were similar in length and weight. Only switched fivers to a rear living for more long term stay comfort as retirees. Went FROM Keystone to FR.
DO RESEARCH ON YOUR SPECIFIC NEEDS AND PLANS.
SilverbackMel is offline   Reply With Quote
Old 03-14-2016, 08:49 AM   #49
BandJCarm's Avatar
Just installed.......ready to order TT:
BandJCarm is offline   Reply With Quote
Old 03-15-2016, 09:04 AM   #50
The Pullrite is a solid hitch. Once I saw how it captures the pin I was sold. The only downside (more of an upside really in the big picture) is that it is built to tighter tolerances than other hitches (as in, an extra decimal place). That, combined with the way the pin is locked in with the rotating plate instead of the jaws, can lead to some frustrations for the first few couple/uncouple cycles. I had to give it a good bump to get it to lock on the first couple of trips. And to get it to unlock it is imperative to make sure you have pressure reversing against the hitch when you pull the handle. Basically, after you've dropped the landing gear and unloaded the weight off the truck, get back in and reverse against the trailer, set the parking brake, and then put it in park. The hitch will release easily with a finger tug. Try to unlock it with any load pulling on the rotating plate and it will not move. It can be frustrating at first, but when you consider that it just means there is less slop in the coupling it becomes a good thing.
2014 Silverback 35QB4
2012 Ram 3500 6.7/slushbox
MIFarmer is offline   Reply With Quote
5th wheel, hitch, wheel
