Old 07-29-2016, 12:57 PM   #1
Crabby
6-point Level up system
Anyone have trouble with jacks coming down in transit or parked? if so, what was the cause?
Crabby is offline   Reply With Quote
Old 07-29-2016, 01:06 PM   #2
Electric or hydraulic? We have the electric and haven't yet had the problem. Seems I did see a couple of threads on here about the hydraulic ones dropping down.Might do a search.I'm pretty sure someone eles will be along to help out.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
DaveandSue is offline   Reply With Quote
Old 07-29-2016, 09:26 PM   #3
wls
I'll never know until the hit the ground, can't see them
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
wls is offline   Reply With Quote
Old 07-29-2016, 11:28 PM   #4
keith52's Avatar
On a previous 5th wheel, I had a landing gear leg that would creep down while driving. The factory rep. got me into Lippert and they replaced that leg. They said it had a bad o-ring and would not hold the pressure. It didn't leak hydraulic fluid, so I'm guessing it was an internal leak.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 07-30-2016, 05:29 AM   #5
wls
my brother has a Design Suites, his was creeping down. He took it to the factory, they did a quick test, replaced the leg.
Old 07-30-2016, 09:46 AM   #6
If there are no leaks and it happens to just one leg, it is an internal leak in that particular leveler. If it happens to more than one leg, it is most likely one of the solenoid valves leaking internally at the pump.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 07-30-2016, 11:42 AM   #7
2007 WildCat 32QBBS
18CrewDually's Avatar
More than likely you have a bad piston seal allowing the fluid to transfer internally bypassing the piston allowing the rod end to drift down.
Salution, warranty should cover it and have it replaced or on your own dime have it rebuilt at a local hydraulic shop.
18CrewDually is offline   Reply With Quote
Old 08-01-2016, 10:38 AM   #8
We have that on all the jacks that are up when it sits for months. Quite frankly, it's easy to ignore. Just retract the jacks before travelling. Unless of course you like to tear into things and burn a lot of time.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
