09-25-2017, 09:04 PM
6 point Lippert Hydraulic leveling
Right front (as you are looking at the front of my CC 5th wheel) blew out at O ring (my guess) as its leaking like a sieve. Called Lippert and their immediate response was, we will send you a new one ASAP and you ship back the old. GREAT response from the first guy I talked to.
My question is has anyone else hand any issues with the Lippert Auto level system? While I think I serves a purpose overall I would rather have a manual system, I can level up in about 5 min going manual and its fairly bullet proof, but my CC came with Lippert 6 point auto so I will live with what I have. But I am wary of its long term reliability...
Don
US Army Infantry Retired
Texas Hill Country
Cedar Creek Silverback 29RE
'19 F 350 CC, LB King Ranch Ultimate
09-25-2017, 09:12 PM
No issues with mine. I love it
If not camping, I am Sailing
09-25-2017, 10:03 PM
i'll never buy another rig without it. I've had it on my '14 CC and the only problem I had was the hydraulic hose ballooned. This was changed under warranty earlier this year.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
09-25-2017, 10:26 PM
You don't have to use auto.. just push the up/down arrow until you see "manual mode", push enter and now you can level up manually... I do it all the time. I use manual mode most of the time, especially in spots that are highly un-level.
Just remember you have to select the "retract" button when you want the rams to rise.
I love mine though, no issues in 2 years+ and over 13000 miles towing.
09-25-2017, 10:52 PM
Mine is almost 6 years old. The one problem I had was one rear jack that had a very slight leak. They replaced it under extended warranty, no problem. I, like others, will never have another rig without it
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-25-2017, 11:44 PM
Mine blew a seal on one jack when it was about two weeks old.
The dealer warranty guy said they had to remove the jack, send it out for repair, then re-install. This would take several days.
I asked where the hydraulic shop was. We ended up taking the trailer to them and they fixed it, still on the trailer, in about three hours.
No problems since then.
Chris and Pat
2023 Ram 3500 Cummins Aisin Dually, Auto Flex Air Ride Rear Suspension, B&W RVK3600 hitch
2022 Grand Design Reflection 303RLS
2024 Winnebago Minnie 2327TB B&W Continuum Hitch
09-26-2017, 08:17 AM
Greatest thing on the trailer.
As said, use manual if you like manual.
But I'm not sure what broke on yours. ??
FROG AR-0019-242
09-26-2017, 09:04 AM
I would not buy another trailer without the 6 point leveling system!
We have had our trailer since May of 2015 and have had no issues with the system.
If you truly failed an O-ring a hydraulic shop can easily fix this in a couple of hours or less.
Friends of mine and I have had major issues with the electric motor driven front legs on the manual leveling systems.
I failed a fuse on my the motor when the legs where over extended trying to level the trailer.it was a special fuse that the local auto stores do not carry. I had to find an RV dealer that had a fuse for sale. So they all have issues.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
09-26-2017, 09:37 AM
As others have said, I also won't have another unit without it. I use ours in manual mode most of the time.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
09-26-2017, 11:39 AM
If I could order a Cedar Creek without one I would. I could spend the $6,000 bucks on full body paint. But to each his own
09-26-2017, 02:40 PM
Thanks all for the positive comments.
I can take or leave the Lippert system and overall I give it good marks and expect and hope its the wave of the future...
Don
Texas Hill Country
09-26-2017, 03:04 PM
Isn't sailing just camping but on the water and you can't walk anywhere
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-26-2017, 03:48 PM
No slide outs or leveling. You want to lean
09-26-2017, 04:11 PM
X2
2015 GMC Denali 3500 4X4 Duramax
2019 Cedar Creek 36CK2 (sold 4/21)
09-26-2017, 05:27 PM
Love the self-leveling feature. Maintenance is important. I keep an eye on fluid levels and make sure the extensions are clean. Dirt can scratch them and cause leaks.
09-29-2017, 08:51 AM
I just got my new 2017 360PDEK with the Lippert system and used autolevel to set it up for it's first use. Yesterday I was going to hook up and move the camper, but the Lippert system would not turn on. Anybody have any suggestions or have ran into this issue before? I will be contacting FR support later on today.
09-29-2017, 08:52 AM
Fuses or battery
09-29-2017, 08:59 AM
Originally Posted by NMWildcat
Fuses or battery
X2. Or, is your battery disconnect turned to off?
09-29-2017, 09:28 AM
Good questions, the master battery switch is on and the batteries are fully charged. I also tried activating the unit with external power supplied, no difference. As for fuses, there is one near the control panel that I checked, it was fine. Are there other fuses I need to check?
My wife was outside looking at the control panel when I brought the slides in and she told me that the control panel displayed a message about the slides retracting, so this makes me believe that the control panel is actually functioning in some capacity.
09-29-2017, 09:56 AM
Mine has fuses between the control panel and the battery, like you have found. They can be regular fuses or mini-circuit breakers. Mine also has a 12v blade fuse in the main breaker/fuse box.
If you are getting messages on the main control panel, then power looks good. Might try removing all power, shore and battery, to reset control panel.
Let us know your resolution when you find it!
