Old 03-08-2015, 04:41 PM   #11
Originally Posted by Jerry01 View Post
Are you hooked up to shore power, or just using your batteries? Jerry.
Shore power
rick03hd is offline   Reply With Quote
Old 03-08-2015, 05:04 PM   #12
try looking under troubleshooting in your level up manual,grounding is telling you something,your dealer should help or lippert directy
Big Bill is offline   Reply With Quote
Old 03-08-2015, 05:05 PM   #13
I have emailed Lippert Guess I will call them in the AM Thanks
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
Old 03-08-2015, 06:57 PM   #14
In the front compartment where the landing gear is on the back wall is a group of 4 or 5 grey circuit breakers. I believe 2 or 3 of them are manually resetable with a tiny black button on the side. One of these is power for the level system and may be tripped. You will still have power to panel but not the legs.
dolsen is offline   Reply With Quote
Old 03-08-2015, 06:59 PM   #15
I'll see if I can locate them in the morning.
Thanks.
2015 CC 36CKTS
2011 Ford F-250
2003 Harley Ultra Classic
2016 Ford F350 DRW
Old 03-09-2015, 07:35 AM   #16
Your camper is new. Have you considered calling your warranty service provider coach-net.
I have never used them, but I would think that they should provide some sort of assistance.
2 for the road is offline   Reply With Quote
Old 03-09-2015, 08:04 AM   #17
Yes that is my last choice. In my life's learning process I always try to solve problems so that I may better learn systems.
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
Old 03-09-2015, 08:28 AM   #18
lgray's Avatar
Perhaps better that it was not working when you hit “Auto Retract All”. I was told by my tech at PDI, that on the hydraulic system, that function will drop the jacks all the way down to the ground…perhaps damaging the underside components on some fifth wheels. You can accomplish everything you need by manual retract.
lgray is offline   Reply With Quote
Old 03-09-2015, 08:31 AM   #19
I was attempting auto level not auto retract. When it did not work I attempted to operate manually. Still didn't work. I am emailing back and forth with Lippert now.
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
Old 03-09-2015, 08:31 AM   #20
lgray's Avatar
Also read a post where the user disconnected shore power, removed the battery cables, reconnected and when it re-powered, seemed to reset itself.
