Old 03-09-2015, 08:33 AM   #21
That is what I am going to try if Lippert can't give me any solutions. Lippert says it must have 12.6 volts or pump will not operate. Have not checked voltage yet.
2015 CC 36CKTS
2011 Ford F-250
2003 Harley Ultra Classic
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
rick03hd is offline   Reply With Quote
Old 03-09-2015, 08:52 AM   #22
Witch Doctor's Avatar
2015 CC 36CKTS
2011 Ford F-250
You could reset your panel by pulling out the plug behind the board for 10 seconds, then replug it in ...Should reset the panel. Do you have rocker switch that just drops or raises the landing legs? If so raise the front end and push auto level again. If that will not do it you will need to do the reset. Please let us know what happens and how you got it working again so we all can learn....Thanks
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 03-09-2015, 08:53 AM   #23
Did the reset yesterday nothing changed.
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
Old 03-09-2015, 10:02 AM   #24
extremebike's Avatar
If you are on shoe\re power only then the converter does not have enough juice to power the leveller system. If the battery is really low then it will not operate even if hooked into shore power.
The dealer drained my battery when it was in for service. Jumping the RV battery from a vehicle did not work until the jump vehicle was started. It takes a fully charged battery to ensure the Level Up system works correctly.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 03-09-2015, 12:28 PM   #25
Maybe ya'll can Help
My hydraulic leveling system is NOT working. When I turn it on and press retract then rear it clicks but nothing else. When I hit auto level it says grounding then times out. Any suggestions
Rick,
It sounds like your manual reset mini breaker may be popped. These are located in the very front compartment, nearest your pin box. I have circled the buttons you will want to press.
Jeff
Name:	Manual Reset Mini Breakers.jpg
CEDAR CREEK REP JH is offline   Reply With Quote
Old 03-09-2015, 12:36 PM   #26
Yep it is the mini breakers. When I reset and attempt to level it pops again
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
Old 03-09-2015, 12:45 PM   #27
2015 CC 36CKTS
2011 Ford F-250
If the mini breakers are continuing to pop, there is a good chance it is because of low battery voltage. When voltage decreases, current increases. These are 50amp mini breakers and if the voltage is too low, it will cause them to pop. I recommend resetting the breakers, charging your batteries, and then trying it. If you are in an emergency situation where you don't have time to charge, hook up the 7-way cable to your truck and you may be able to draw from your truck's batteries.
Another thing that could cause these breakers to pop is if you are trying to Auto-level and the jacks are too far retracted. Try to manually extend the jacks about 6" and then press Auto-level. When the system attempts to Auto-level it has to do an initial drop when the jacks will slightly retract first, and then level itself. If it cannot do this initial drop, the motor will continue to run and the solenoids will not open until A- your motor burns up, or B- a breaker pops (luckily we have breakers so we don't burn up the pump).
Give these a shot and if none of this works, let me know.
Jeff
Old 03-09-2015, 12:51 PM   #28
Ok. I've checked the voltage 13.8
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
Old 03-09-2015, 12:57 PM   #29
2015 CC 36CKTS
2011 Ford F-250
13.8 volts should be plenty, try to manually extend your jacks and then Auto-level.
File Type: pdf Automatic Level Up operating instruction.pdf (126.2 KB, 37 views)
Old 03-09-2015, 12:59 PM   #30
That's my next step when I get back.
And thanks. It's nice to know yall monitor these forums
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
