Old 03-09-2015, 01:54 PM   #31
check your oil I had the same problem .oil leak
wire1946 is offline   Reply With Quote
Old 03-09-2015, 01:55 PM   #32
Checked that it's ok. But thanks
2015 CC 36CKTS
2011 Ford F-250
2003 Harley Ultra Classic
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
rick03hd is offline   Reply With Quote
Old 03-09-2015, 01:57 PM   #33
do you have your batteries sw on?
Old 03-09-2015, 02:05 PM   #34
Yes. 13.8 volts on that circuit. It's tripping the mini breaker.
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
Old 03-09-2015, 02:30 PM   #35
Problem solved. Left side jacks were fully extended so it was tripping breaker trying to extend more. Retracted jacks added a 2" block under left side and it works now.
Thanks to all who offered help
And thank You
Jeff at Cedar Creek.
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
Old 03-09-2015, 02:34 PM   #36
dicky1243's Avatar
Originally Posted by rick03hd View Post
I was attempting auto level not auto retract. When it did not work I attempted to operate manually. Still didn't work. I am emailing back and forth with Lippert now.
2015 CC 36CKTS
2011 Ford F-250
On my trl. 6mos. old my jacks quit working and my service man told me that in the front of my sierra 2013 there are a couple of 50amp breakers that operate the hyd. and to take screw and go between the power term. and the oposing term. and press the sw. to raise the landing gear it worked.
But when he said there should be 2 breakers for the landing there was only 1 for the gear and one going to converter. I went into a rv shop and bought 2 breakers and a 6ga wire to run them in paralell been working great ever since.
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 03-09-2015, 02:48 PM   #37
Witch Doctor's Avatar
And thank You
2015 CC 36CKTS
2011 Ford F-250
Glad it working now. So you were maxed out of stroke on that Ram is what your saying?.......
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 03-09-2015, 02:49 PM   #38
if your tripping a cb it's short or a over load .when does it trip?as soon as you turn it on
Old 03-09-2015, 03:17 PM   #39
When I get the camper where I am going to set up at, then I measure how far each pad is from the ground and then I make all pads level or about level. The level-up only knows when it hits something firm, I use to sometimes pick the tires up on one side but not anymore. I carry plastic pads just for this, works for me
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 03-10-2015, 06:52 AM   #40
Yes. When it reached max stroke it tripped breakers.
Life is a learning experience.
2016 Ford F350 DRW
