Old 03-10-2015, 07:54 AM   #41
rugersdad's Avatar
Have you checked for power at the contactor switch as I suggested in an earlier post? It directs power to the 12 volt motor that drives the hydraulic pump. I am assuming that your level up system is similar to mine.
rugersdad is offline   Reply With Quote
Old 03-10-2015, 08:41 AM   #42
rugersdad's Avatar
I missed the last page, glad you got it figured out.
Old 03-10-2015, 03:06 PM   #43
Had the same thing happen. Took to dealer for warranty. They said it was loose battery wires. Snug your connections at battery and at hydraulic pump first to see if that's the problem.
dkelly is offline   Reply With Quote
Old 03-11-2015, 09:32 AM   #44
I'm sure you have the level up fixed by now but I wanted to tell you there is a reset button to push. That has happened to us more than once.
Jokerbgood is offline   Reply With Quote
Old 03-11-2015, 09:40 AM   #45
Yes. The problem has been solved.
Thanks for your reply.
Those little resets are pretty well hidden.
2015 CC 36CKTS
2011 Ford F-250
2003 Harley Ultra Classic
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
rick03hd is offline   Reply With Quote
Old 03-11-2015, 09:41 AM   #46
You can say that again! Safe travels 😃
