03-08-2015, 02:18 PM
6 Pt Level up NOT Working
Maybe ya'll can Help
My hydraulic leveling system is NOT working. When I turn it on and press retract then rear it clicks but nothing else. When I hit auto level it says grounding then times out. Any suggestions
03-08-2015, 03:45 PM
Have you tried manual mode? Can you raise or lower the jacks in manual?
03-08-2015, 03:53 PM
Try "auto retract all" to get the system back to its starting point. Then try and re-level. If it is you 5th in in your avatar pic, of course you must re-engage your truck to the rig first.
Brenda and John
Master Blaster of the Navy
03-08-2015, 04:06 PM
Wont work in manual Just clicks
03-08-2015, 04:07 PM
Can not do anything.
03-08-2015, 04:12 PM
There's also a re-set nipple that is very challenging to find. Follow the red electrical lead from the hydraulic pump to the power supply connection (I'll have to get a photo of this sometime). Behind where the bolt is that you tighten to hold the electric lead, is where you'll find this tiny little re-set button, press that down so that it reconnects and remains pressed in.
My dealer showed me this last year when I couldn't get my 6pt leveling system to work. Apparently a slight drop in power could cause this to trip. For me, it was the fact we'd had the trailer connected to the battery but not used it for about 6 weeks. I got the trailer to raise the legs when we hooked up but when it came to dropping them again at the CG it wouldn't work. To all intent and purpose, the control panel looked as if it was working properly and it had power. Mine had just tripped this very small, hard to find button.
Richard & Diane
2014 Cedar Creek 38FL
With an F350 DRW
Richard & Diane
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
03-08-2015, 04:14 PM
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
03-08-2015, 04:22 PM
My Cardinal has a re settable circuit breaker in battery comp that trips sometimes disabling the electric motor for the pump, otherwise use a test light on the contactor switch where polarity is reversed to turn pump forward or backwards to raise and lower jacks. I have had to replace it once already. Hope this gets you in the right direction.
03-08-2015, 04:32 PM
Originally Posted by 38FLCamper
Tried the reset Did not work.
03-08-2015, 04:40 PM
Are you hooked up to shore power, or just using your batteries? Jerry.
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
03-08-2015, 04:41 PM
Shore power
03-08-2015, 05:04 PM
try looking under troubleshooting in your level up manual,grounding is telling you something,your dealer should help or lippert directy
03-08-2015, 05:05 PM
I have emailed Lippert Guess I will call them in the AM Thanks
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
03-08-2015, 06:57 PM
In the front compartment where the landing gear is on the back wall is a group of 4 or 5 grey circuit breakers. I believe 2 or 3 of them are manually resetable with a tiny black button on the side. One of these is power for the level system and may be tripped. You will still have power to panel but not the legs.
03-08-2015, 06:59 PM
I'll see if I can locate them in the morning.
Thanks.
2015 CC 36CKTS
2011 Ford F-250
2003 Harley Ultra Classic
2016 Ford F350 DRW
03-09-2015, 07:35 AM
Your camper is new. Have you considered calling your warranty service provider coach-net.
I have never used them, but I would think that they should provide some sort of assistance.
03-09-2015, 08:04 AM
Yes that is my last choice. In my life's learning process I always try to solve problems so that I may better learn systems.
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
03-09-2015, 08:28 AM
Perhaps better that it was not working when you hit “Auto Retract All”. I was told by my tech at PDI, that on the hydraulic system, that function will drop the jacks all the way down to the ground…perhaps damaging the underside components on some fifth wheels. You can accomplish everything you need by manual retract.
03-09-2015, 08:31 AM
I was attempting auto level not auto retract. When it did not work I attempted to operate manually. Still didn't work. I am emailing back and forth with Lippert now.
2015 CC 36CKTS
2011 Ford F-250
2016 Ford F350 DRW
Also read a post where the user disconnected shore power, removed the battery cables, reconnected and when it re-powered, seemed to reset itself.
