Old 08-19-2014, 10:35 PM   #1
6-pt leveling
Does the 6-pt leveling system constantly level the unit if there is a shift? i.e. ground is soft and rain tends to make one side level off a bit.
just wondered, as we hear some pops and things like the system is adjusting, though the leveling mon. is turned off. so not sure.
thanks.
stormy2000 is offline   Reply With Quote
Old 08-19-2014, 10:38 PM   #2
Plain Old Member
Once it's set, it's set. Does nothing else on it's own. The pops are common in this system. Usually caused by air in the fluid, or I've notice just with temp changes from morning till evening. You can reduce this popping noise by adding the anti-stiction fluid recommended by Lippert. I'll post the instructions if I can find them.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-19-2014, 10:40 PM   #3
Plain Old Member
Here you go.
File Type: pdf LCI Hydraulics Anti-Stiction Fluids.pdf (504.6 KB, 130 views)
Old 08-19-2014, 10:54 PM   #4
it is not constantly leveling. You are hearing very small movements of metal parts as explained by Lippert.
If there is a popping noise in a Lippert leveling system, Lippert has approved adding a quart of anti-stiction fluid. Anti-stiction additives do not work by eliminating air from the system. They work by lubricating the hydraulic system so you do not hear the noise made by the valves in the system that are there to equalize or protect the system. Even though you are not running your hydraulics, temperature changes and load changes still affect the system and it will make slight changes which is what you are hearing.
From Wikipedia.
Stiction is the static friction that needs to be overcome to enable relative motion of stationary objects in contact. Any solid objects pressing against each other (but not sliding) will require some threshold of force parallel to the surface of contact in order to overcome static cohesion. Stiction is a threshold, not a continuous force.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 08-20-2014, 06:32 AM   #5
Mddle of the Rd Extremist
MeepMeep's Avatar
Originally Posted by BigJohnD View Post
Here you go.
Thanks BigJohn......been wondering how to get rid of the poppin' noises. Of course they're always loudest at night (when it's cooler) when you're tippy toein' around, trying NOT to make any noise
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 08-20-2014, 06:49 AM   #6
Plain Old Member
We've done that procedure once, and the popping came back a little. Hadn't done round 2 of it yet. Curiosity got the best of me when it was new and doing that, so I measured the jack stroke on the 6 jacks. I checked every hour for a full day. There was actually a bit of change, but ever so slight.
We put jack stands right next to the front jacks on the frame just to see if it'd stop, and that completely rid of the popping. Like any hydraulic system, they will move a little. I can pick the front loader on the tractor up a little and let it sit, and it will do the same thing if you sit and listen long enough.
Sent by ME
Old 08-20-2014, 08:30 PM   #7
thank you for the link, reading up on it and see about trying that. also does anyone with the 6-pt leveling system use the tripod under the cap? I see my neighbors using the tripods, but they don't have the 6-pt leveling so was wondering if that is a normal thing to do. thanks again.
Old 08-20-2014, 08:39 PM   #8
We have a six point system and do not use a pin stabilizer. Our bed is on a slide out and is directly over the landing gear -- very stable.
Our issue with stability revolves around energetic kids at the other end of the trailer in the bunkroom. The entire bunkroom is behind the rearmost jacks so they can set the trailer rocking even with X-Chocks.
Home Port Orlando
Old 08-20-2014, 08:50 PM   #9
Plain Old Member
Tripod doesn't work well in our opinion. Some, but not much. Our plan is to build something similar to what others have done. Pretty much a combination of the JT Strongarm and Steadyfast idea. This in my opinion is about as good as it's gonna get in a trailer. We've used the X-chocks for years, but that doesn't solve the front or back end moving side to side like Narboza mentions.
I wonder what ever happened to not giving a crap about the camper moving. Used to none of that bothered me a bit, as it's a camper. The older I get, the grouchier and more picky I get I suppose.
Old 08-20-2014, 08:51 PM   #10
Plain Old Member
Forgot to mention, Lippert does make a weld on tab for the level up feet, if one chooses to install a JT Strongarm set. I'm just going to make my own weld on tabs.
Old 08-20-2014, 09:08 PM   #11
thanks for info, will check on that weld.
Old 08-20-2014, 09:16 PM   #12
Plain Old Member
Here's a link to the adapter lug for the level up / JT Strongarm stabilizers:
JT's Strong Arm™ Jack Stabilizer Adaptor Lug for Hydraulic Fifth Wheel Landing Gear Legs – Lippert Components, Inc Online Store
Old 08-21-2014, 09:31 PM   #13
Thanks for link, great info.
Old 08-21-2014, 09:40 PM   #14
Plain Old Member
Not sure if you've got the manual for the system, but just in case here it is. If you haven't been shown how to recalibrate the system to what YOU say is level, it's on page 3 under "Zero Setting The Control". Very simple. We leveled ours using multiple levels in key places inside, then set some bubbles front and side and set the system. We did use the auto feature for a while, but after having to recalibrate, or zero the system several times, we just went to using it in manual mode all the time.
Old 08-22-2014, 02:58 PM   #15
SilverbackMel's Avatar
GHOSTS OF PAST AMISH CRAFTSMEN TRYING TO LEAVE GOSHEN!! May the Force be with you😊
SilverbackMel is offline   Reply With Quote
Old 08-22-2014, 08:18 PM   #16
thanks for manual, am going to try that recalibrate system and see how that goes. thanks much.
Old 08-22-2014, 09:32 PM   #17
Plain Old Member
stormy, have you put any bubble levels on the unit? Just curious where you'd have a reference to go by at the controls. Some have had good luck with theirs staying calibrated. Mine, on auto, it'd say "Oh yeah, watch this crap" every now and then.
Old 08-23-2014, 12:51 AM   #18
I use the regular bubble level I got at home depot, it has 3 different bubbles from which to measure @ different angles. and they show the unit is stable. all came down when we started hearing those popping nosies and like little bumps in the unit, which made us wonder if the unit is self adjusting or are we moving due ground shifting *our area is little sandy also* .. and our unit is not self adjusting but just moving with the ground.
every time i check the level mon. it shows good, and the bubble is also about even.
Old 08-24-2014, 06:25 PM   #19
IMO the popping problem is with the front jacks. It's also worse the further out they have had to be extended due to any sloping of the site. The sure cure is to slam some simple jack stands underneath the frame and unload the front jacks. You've already learned that the Lippert system makes no other adjustments once it thinks the trailer is level. It actually turns itself off. I have it but don't always use it because I don't like my wheels hanging up in the air on awkward sites.
Sterlingsilver is offline   Reply With Quote
Old 08-25-2014, 07:35 PM   #20
Duckogram's Avatar
Two screw type trailer Jack stands available from Wally Mart took out almost all of the bounce on my 36CKTS. I put them under the corners of the trailer hitch. I used a king pin stab as well but not as a stabilizing device. More like an anti-theft for the bikes.
ILB ( | )
leveling
