Old 08-18-2013, 06:06 AM   #11
Looks like you have more room above your batteries than I do. I tried all sort of tricks and finally decided that the aggravation was not worth it. It cost me $135.00 altogether, but I'm happy now! There is no boil over or other mess and filling the batteries is easy now. Here is what I got. You have to order 2 of them plus the squeeze bulb filler thingy.
RV Battery Watering System - $50.99
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-18-2013, 06:59 AM   #12
Campingnut's Avatar
I have the pro fill watering system in my trailer, with the 6 volt batteries the same as you, and I find it works great. It fills the batteries to exactly where you need to and no more.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 08-18-2013, 07:36 AM   #13
jerseyboy's Avatar
Thanks for all the replies. I think with the tight space where the batteries are I will go with one of the watering systems.
Mike
jerseyboy is offline   Reply With Quote
Old 08-18-2013, 11:54 AM   #14
you have a lot of room .I can only get to one battery.do you have a 18 cf ref ?and are all your batterys in series?what is your out put voltage on your inverter.mine is about 12.1 volts
wire1946 is offline   Reply With Quote
Old 08-18-2013, 12:09 PM   #15
jerseyboy's Avatar
Yes I have the residential refrigerator I will have to check the output.
Old 08-18-2013, 12:10 PM   #16
jerseyboy's Avatar
And yes the batteries are in series.
Old 08-18-2013, 02:19 PM   #17
Triguy's Avatar
I think you mean series-parallel for your bank of four 6-volts
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-18-2013, 04:00 PM   #18
Former Full Timer
Duckogram's Avatar
Output for your inverter should be 110v.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 08-18-2013, 04:43 PM   #19
Former Full Timer
Duckogram's Avatar
I don't think the two pairs that are wired in series are then paralleled to to increase capacity. One pair is for the house system and the other pair should be dedicated to the inverter to power the fridge... I also noted that the newer 36 CKTS have a different inverter in a different location than my late model 2012.
Old 08-18-2013, 06:25 PM   #20
Triguy's Avatar
Ah. That's what I get for assuming it was a typical four 6-volts as one bank. Mea culpa.
Scott
2012 Shamrock 233S
battery
