Old 11-08-2013, 12:55 PM   #31
mlatter's Avatar
You can see that the two pairs are wired together. The closest black wire going from one pair to the other, and the red wire with the black tape joining the hot side. It's wired essentially the same as the diagram I posted earlier. Oh, you're not in the Hilton Head resort and marina are you? There's a rig here that looks like the picture of yours.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 11-12-2013, 10:23 AM   #32
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
I too have a CC w/ 4 6 volt batteries. I use a mechanic's inspection mirror to see the fluid level in each cell & an $8 oil transfer pump from Napa that screws onto a gallon jug of distiller water to service. Works for me.
Travel safe & enjoy
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 11-12-2013, 10:36 AM   #33
Denver, CO
garbonz's Avatar
Originally Posted by Duckogram View Post
I don't think the two pairs that are wired in series are then paralleled to to increase capacity. One pair is for the house system and the other pair should be dedicated to the inverter to power the fridge... I also noted that the newer 36 CKTS have a different inverter in a different location than my late model 2012.
You'd better check that cause it sure looks like the 2 series set are wired in parallel
2017 Fuse 23T
Old 11-12-2013, 02:20 PM   #34
Former Full Timer
Duckogram's Avatar
Not us but we spent the Summer up your way 1/2 in Cape Breton and the other half on PEI. Loved it!
I did look at your diagram and agree. Did you notice the red lead going from a pair of batts directly to the inverter? That's what caused the second take and why I posted the pics for you. Thanks.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
battery
