Old 08-17-2013, 01:59 PM   #1
jerseyboy's Avatar
6 Volt Battery Fill
On my 36CKTS I have 4 6 volt batteries. I am looking to top them off but I am very limited with space because there is a shelf where the inverter sits. I was looking at a Pro Fill watering system at CW and it looks like I will need 2 sets because I have 4 batteries. Has anybody used this system or any other ideas.
Thanks, Mike
jerseyboy is offline   Reply With Quote
Old 08-17-2013, 04:35 PM   #2
kirk37r's Avatar
6 volt batts
Mike
I cut the box they are in and made it so I can lift the top off on my 38FL.
Kirk, Carol& Nicholas (Grandson)
2013 Cedar Creek 38FL, RV Cams rearview cam
2012 Ram 3500 DRW
CAUTION behind this truck is A contagious disease!!!
Its called Camping!!!
kirk37r is offline   Reply With Quote
Old 08-17-2013, 04:48 PM   #3
Fire Instructor's Avatar
Be very careful filling 6v golf cart batteries! You don't fill them to the "top ring" like you do a 12v standard battery. If you do, they will spill over during a charge cycle. Most recommend only filling them so that the plates have about 1/2" to 3/4" of cover.
An auto-fill system will likely overfill them.
If you need to know how I learned this, it's "been there, done that, ruined a tee-shirt (and a pair of jeans) cleaning up the over-flowed acid"!
Two weeks after I did it, a buddy of mine did the exact same thing, and got the exact same result.......
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 08-17-2013, 06:21 PM   #4
Former Full Timer
Duckogram's Avatar
Joiseyboy,
Fancy does not work well in this application. I suggest you get the following item to water your batteries:
Plastic compact mirror (swiped from DW)
Turkey baster - plastic.
Clear tubing that fits over baster end (2' will do it)
LED Headlight
Distilled H2O
Position the mirror so your headlight shines into the cell. Insert tube into "V" grove in cell. Squeeze the baster till you get the cell full to the bottom of the V groove. Voila!
Note: try not to stick the tube into the battery acid or touch the plates.
Hope this helps.
P.S. if your inverter is above your batts, where is your level-up and hydraulic pump?
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 08-17-2013, 06:31 PM   #5
jerseyboy's Avatar
Ducky
I think I will try the mirror trick with some surgical tubing.
My inverter is below the hydraulic pump and above the batteries.
I will have to use a mirror because you can not look into the cells on the batteries.
Thanks, Mike
Old 08-17-2013, 08:40 PM   #6
CCRVOC
Ramblin Recks's Avatar
Thanks, Mike
I don't have them on my rig yet, but I know golf cars. We use Flow-Rite single point watering system. It uses automatic shut off valves and a snake (interconnected hoses to all valves). Very easy to use. and you can hook up the snake to all four batteries so you only have one water valve. Good investment for expensive batteries! CW has the same price listed that Flow-Rite does.
BTW, where are you batteries located? My battery (36ckts) is under the hydraulic pump, but I'll be adding 4ea 6v later.
Reck
Ramblin Recks is offline   Reply With Quote
Old 08-17-2013, 09:04 PM   #7
jerseyboy's Avatar
Reck
Mine are under my inverter witch is under the pump they are really stuffed in there.
Mike
Old 08-17-2013, 09:34 PM   #8
CCRVOC
Reck
Mike
Are those batteries on the driver side towards the front?
Old 08-17-2013, 09:37 PM   #9
jerseyboy's Avatar
Yes where the hydraulic pump and level up system is.
Old 08-17-2013, 09:44 PM   #10
CCRVOC
Wow, yes that is a tight space for sure.
battery
