Old 02-23-2015, 09:45 PM   #1
a/c is not cold enough
we haven't run our a/c lately due to it was cold, but now with the temps going up a bit, we turned on our a/c (sb 31rk), and the living room a/c 15k runs but is not putting out cold enough air. it is cool but not cold, seems to be the same as if we are running the fan.
don't know what else to check, have looked at filter, thermostat, the bedroom a/c 13k works good. the front a/c comes on when the temps hit setting but the air is not just not cold enough, while running during the day, the temp inside goes up a bit instead of going down.
thanks bill & jodi
stormy2000 is offline   Reply With Quote
Old 02-23-2015, 10:05 PM   #2
VinceU's Avatar
A digital thermometer would help describe the output of the unit. Indicate low refrigerant or cooling unit just not working. should measure anywhere from 10-20F temp drop from room temperature to achieve outlet. Lots of causes for no output.
Old 02-23-2015, 10:17 PM   #3
beechjr's Avatar
Sounds like compressor not coming on, fan just running? Need to have system checked with A/C gauges? Could be several issues, low freon, pressure switch Etc....
2013 Forest River Blue Ridge 3025RL
2005 Chevy 3500 Crew Cab Duramax
beechjr is offline   Reply With Quote
