Old 06-28-2015, 03:48 PM   #1
AC will not stay running...
Keep getting an "E6" error when turning on our AC ...Can find anything as yet in our manuals...any suggestions?
Truck 2009 GMC 2500 HD,D/A,Ext.Cab,SB,air bags, lift kit, flow gate, etc.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
Camping Day's: 2012:25,2013:27,2014:38,2015:38
Little John is offline   Reply With Quote
Old 06-28-2015, 04:08 PM   #2
TURBS's Avatar
Error Code:
E1 Loss of communication between the
CCC 2 thermostat and all system power
module boards. System will shut down.
CCC 2 thermostat and an individual sys-
tem power module board. The LED will
display error code E1 and the zone num-
ber that lost communication. Any addi-
tional zones that lose communication will
blink in addition to the current zone.
E2 Open circuit or out-of-range Indoor Tem-
perature sensor. All heat, cool, and de-
humidify operation will be locked out.
Manual fan operation can continue.
E3 Shorted Indoor Temperature Sensor. All
heat, cool, and dehumidify operation will
be locked out. Manual fan operation can
continue.
E4 Open circuit or out of range Outdoor
Temperature Sensor (Select Models).
Heat pump and dehumidification opera-
tion will be locked out. Air conditioner,
furnace, heat strip and fan operation can
continue to operate.
E5 Open circuit or out of range Freeze Sen-
sor (Select Models). Air conditioner and
dehumidification operation will be locked
out. Heat pump, furnace, heat strip and
fan operation can continue to operate but
displays the last temperature set-point.
E6 Open circuit Humidity Sensor (Select
Models). Air conditioner and dehumidifi-
cation operation will be locked out. Heat
pump, furnace heat strip and fan can
E7 Loss of 120 VAC power to all power mod-
ule boards on the system. The system
will shut down.
E8 Invalid zone configuration. The heat
pump and heat strip DIP switches are
both set to the ON position in one zone.
Heat pump, heat strip, air conditioner,
and dehumidify operation will be locked
out in the affected zone.
E9 Invalid zone configuration. The dehumid-
ifier DIP switch and either the heat pump
or heat strip DIP switches are set to the
ON position in one zone. Heat pump,
heat strip, air conditioner, and dehumidify
operation will be locked out in the affect-
ed zone.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 06-28-2015, 05:43 PM   #3
Thanks for the error codes I shall make note of them.
Sorry dumb baker here...not sure what the E6 means and how to fix it???
Old 06-28-2015, 05:56 PM   #4
Herk7769's Avatar
You are running the temp too low and the AC is not cycling like it should.
That is icing up your coils.
The E6 is telling you it has shut down your compressor so the ice can clear off the coils.
Tip: Always set your thermostat to 10 degrees BELOW outside air temp (OAT) up to 100 degrees OAT (90 inside).
This will allow the AC to cycle (turn on and off) to dehumidify and cool the dryer air.
HAM CALLSIGN - KC3FFW
Old 06-28-2015, 06:14 PM   #5
I had just turned on for the first time this year and with in a few seconds the error message came in. Would the coils ice up the fast? I many had it on as it had been a while since I had the "genie" up and running...
Old 06-28-2015, 06:53 PM   #6
Herk7769's Avatar
The other possibility is "open circuit" (what happens to the sensor when it ices up). A rodent could have bitten through a wire.
Old 06-30-2015, 07:40 PM   #7
Update on this...
Going to bring our unit home tomorrow and see if the AC works when plugged into shore power...thinking maybe there's an issue with power from the generator...
After letting the unit sit 2 days,tried it again and as soon as it started the E6 message came on...
Have had an issue from day one with the way the genset was installed...wishing I never added to this unit!!! :-(
Old 07-01-2015, 09:26 PM   #8
Do you know if your ac unit is also a dehumidifier? The e6 code is specific to the ac unit that is a combination dehumidifier. If you do have the dehumidify ac combo you probably have a bad humidity sensor. If not may be a bad thermostat.
We were going to put this type unit in our 33ik but opted for a heat pump instead.
Rich5117 is offline   Reply With Quote
