Old 12-15-2015, 06:08 AM   #11
Originally Posted by etcmss View Post
but you're not sure, I would hate to break it. thanks anyway
I am Sure of one thing,contact your Dealer! I just made a statement on how Most mount! Youroo!!
Old 12-15-2015, 09:45 AM   #12
TV in Living Room
We had a hard time removing our TV also. After We wiggled and jiggled We got it off to find a pull chain on the release (light the kind on light bulb fixtures).
Reach around the left side of TV about 1/3 of the way down and there is the chain.
2014 Surveyor 32RBDS
2013 Ram 2500 Mega Cab
6 months in Florida
and Camp outs in Michigan 5 times a year
SusanML4650 is offline   Reply With Quote
Old 12-16-2015, 05:15 AM   #13
etcmss's Avatar
tv mount
after talk to Forest River Service I found that our mount is connected to the wall mount with a 2 button release.
if snooping with a flashlight from below look for the two buttons, they should be easily visible in the black mount.
access to the 2 silver buttons is from the bottom middle of the tv---push both buttons up and the tv mount bracket should release from the wall bracket. the tv and wall brackets are slid together in a slot at the top. Slide the tv down and away from wall and it should come loose.
etcmss is offline   Reply With Quote
Old 12-21-2015, 05:52 AM   #14
tv wires and mounts
am new owner of a Cedar Creek Cottage 40CCK. Need access to back of TV for a couple of reasons. Can't see a mount release or arm.
Anyone have knowledge on how to get to the connections?
Gary
If yours has the power lift like I was able to see online, then you should be able to get to all the wiring when the TV is in the up position,, I am sure there is some wire guide to stop the wires from becoming stuck, but you should at least see that while up.
If that does not work I would call FR service and ask them
hope this helps Happy camping Merry Christmas
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 12-21-2015, 10:21 AM   #15
etcmss's Avatar
tv access
no my tv is stationary. fixed to wall mount. must remove from wall mount to access connections
Gary
Old 12-21-2015, 10:26 AM   #16
Pickin' & Campin'
the above pictures sure helped.....thanks, now i see what the "V" means.
Gary
Here's another common mount used.
It actually has a 'V' shaped mount.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-24-2015, 03:14 PM   #17
Have a 2016 31rk and the LR tv comes off like sedal10 described.
hughd033 is offline   Reply With Quote
