Old 12-14-2015, 05:53 AM   #1
etcmss's Avatar
Access to back of LR TV
am new owner of a Cedar Creek Cottage 40CCK. Need access to back of TV for a couple of reasons. Can't see a mount release or arm.
Anyone have knowledge on how to get to the connections?
Gary
etcmss is offline   Reply With Quote
Old 12-14-2015, 06:02 AM   #2
Most just pull/lift straight UP to remove,they sit in a V! Youroo!!
youroo is online now   Reply With Quote
Old 12-14-2015, 06:09 AM   #3
wls
wonder if thats the same for the bedroom one?
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 12-14-2015, 08:35 AM   #4
Busybeavers's Avatar
Originally Posted by wls View Post
wonder if that's the same for the bedroom one?
2016 Silverback bedroom TV is just a lift and pull to remove. I did an upgrade and added a small shelf at the top of the mount for a blue ray player. It is an easy removal.
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Busybeavers is offline   Reply With Quote
Old 12-14-2015, 01:16 PM   #5
Stormrider151's Avatar
Lift up and out. I have to wiggle mine a little to get it to loosen up. The first time I tried it didn't want to come up but a little wiggle is all it took.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 12-14-2015, 04:22 PM   #6
etcmss's Avatar
but you're not sure, I would hate to break it. thanks anyway
Old 12-14-2015, 04:29 PM   #7
Ham Camper's Avatar
I had looked at my TV and had no idea how to remove it. Thanks for the info guys
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is offline   Reply With Quote
Old 12-14-2015, 05:04 PM   #8
I have a 2016 CC Silverback. I just took the one in the living room off the mount. On the left side, I had two push buttons that when pushed in allowed the left side to be pulled out to clear the mount. In the right the part of the bracket attached to the TV is a L that slides into the slot on the wall. So, pushed the two buttons on the left in and rotate TV bracket out to clear the wall bracket. Now move the TV to the left to disengage the L bracket from the wall bracket on the right.
You should be able to see if this is the type you have by looking in on each side.
Good luck!
segel10 is offline   Reply With Quote
Old 12-14-2015, 05:49 PM   #9
Oaklevel's Avatar
There are several types of mounts used inside & outside mounts for ours....
ID:	96203   Click image for larger version
ID:	96204   Click image for larger version
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 12-15-2015, 04:52 AM   #10
etcmss's Avatar
the above pictures sure helped.....thanks, now i see what the "V" means.
Gary
