Old 08-22-2013, 07:47 PM   #11
Former Full Timer
Duckogram's Avatar
36 CKTS, never empty the porcelain, no water on the floor. No shocks.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 08-22-2013, 08:32 PM   #12
mike1poles's Avatar
The shock design on multi axle towable's, are not for up and down motion like motorhomes, car's and truck's. It is front to back motion between the axles. If you look at the hanger's you see they are at about a 45 degree angle. That is the reason for the air pin boxes, equal-flex type axle connections, etc., the Dexter air suspension, or MorRyde IS system, this all are designed to help smooth the units ride. I agree with Ducky, we had 7000# axles, changed to 8000#, then changed to MorRyde IS. NEVER had any water from the commode come out, and we've gone over some pretty rough roads. One time (before the IS system), we were on such rough roads, we had three cabinet door opened and broke some things, several pictures come off the wall, but not one drip of water came out of the commode. Actually, most places are taking any shocks off, if they are still on. A few years back, the shocks were twisting, bending, or coming loose. They would rub and cut the tires, causing a lot of damage to units. Before I added anything, I'd talk with Mike at CC, ask him to see what he thinks might be happening in your situation. I'm sure they can come up with an answer.
Hope this helps and God bless,
Mike
Mike and Judy
Wherever we are parked is our home
2009 - 36RD5S
2007 - Dodge 3500 6.7 Cummins
May God bless
WA8MRU
mike1poles is offline   Reply With Quote
Old 08-22-2013, 08:53 PM   #13
Campingnut's Avatar
Do you have any contact information for Mike?
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is online now   Reply With Quote
Old 08-23-2013, 10:43 AM   #14
mike1poles's Avatar
Tim,
Here is the contact info for Mike Antal:
Mike Antal
Technical Retail Service
Service Dept
Forest River, Inc
Cedar Creek Division
501 Hawpatch Dr
Topeka, IN 46571
260-593-2326
Fax: 260-593-3333
email:MAntal@forestriverinc.com
Only have talked with him a couple of times. They have changed people there, in the last few months. But the attitude with Cedar Creek is still the same, customers first!
God bless,
Mike
Mike and Judy
2009 - 36RD5S
May God bless
WA8MRU
Old 08-23-2013, 10:47 AM   #15
mike1poles's Avatar
Tim, I forgot to tell you, Mike at CC will need the last 7 numbers of your VIN number. Sorry about that.
God bless,
Mike
Mike and Judy
2009 - 36RD5S
May God bless
WA8MRU
Old 08-23-2013, 11:02 AM   #16
My Flagstaff has torsion axles and the shocks work great for stopping the bounce of the trailer as well as preventing it from telegraphing to the truck. With torsion axles, there is no back and forth action like on spring suspension and the walking beam. We leave the coffee maker on the rear counter and have towed to FL twice and from NC to Goshen, IN to Trenton, MO and it never moves. Don't know how the shocks can twist and cause damage unless the mounts bend or break.
Old 08-25-2013, 11:11 AM   #17
X2 on the shocks like OC did it. Great mod.
Flying dutchman is offline   Reply With Quote
Old 08-25-2013, 11:31 AM   #18
Garrette's Avatar
Make sure your tires are balanced. I always had my TT tires balanced. Always got a look from the tire guy, why?, I told him so my beer would be fizzy.
Garrette is offline   Reply With Quote
Old 08-25-2013, 02:57 PM   #19
I never had problems with water splashing out in my 2008 37RDQS even before changing the suspension. However, I do have the TrailAir on the front of my 5er. I also now have the MorRyde IS and their disc brakes on it now. I'll never have another 5er without it.
John
John Hagen is offline   Reply With Quote
Old 08-25-2013, 03:13 PM   #20
MC9
I also was thinking about shocks. To keep from flipping my shackles. Had it happen last trip out, now I am real gun shy.
MC9 is offline   Reply With Quote
