Old 08-18-2013, 08:38 AM   #1
Campingnut's Avatar
Adding Shocks
Has anybody ever added shocks to their Cedar Creek? Looks like I have the bar for the slide out in the way on the outside?
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 08-18-2013, 08:43 AM   #2
TURBS's Avatar
Oc added them to his flagstaff if that helps.
Turbs
Old 08-18-2013, 09:55 AM   #3
Are you adding them to help smooth the ride?
Mike & Nan
2014 Cedar Creek 36 CKTS
2013 Ford F-350 4X4 Dually
Mike&Nan is offline   Reply With Quote
Old 08-18-2013, 10:15 AM   #4
Campingnut's Avatar
Yes, and I think it might help with my toilet bowl emptying when going down the road, it splashes out.
Tim and Bev
2015 F-350
Old 08-22-2013, 06:17 PM   #5
you have to drain the toilet before travelling. nothing you do will stop the water in the bowl from sloshing out while travelling. turn off the water pump or turn off the tap if you are hooked up to water and then flush the toilet until empty.
18 3500 denali duramax cc srw
silverback 31b2
skidoonut is online now   Reply With Quote
Old 08-22-2013, 06:37 PM   #6
Campingnut's Avatar
This is the first trailer that I have ever had that does this. Thanks, but that is what I already do.
Tim and Bev
2015 F-350
Old 08-22-2013, 06:57 PM   #7
If your emptying the toilet, then how are you getting water on the floor from it?
OC loves his shocks from what I have read on here about them.
Acableguy06 is offline   Reply With Quote
Old 08-22-2013, 07:06 PM   #8
Campingnut's Avatar
Sorry I was getting water on the floor till I started emptying the toilet.
Tim and Bev
2015 F-350
Old 08-22-2013, 07:17 PM   #9
38FL and I have never emptied the toilet before travel - and no water on the floor.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 08-22-2013, 07:41 PM   #10
Campingnut's Avatar
I think it is because of the 7000lbs axles and heavier tires, and not being loaded close to the higher capacity of the trailer. Everything in the cupboard on the other side of the wall from the toilet is always a mess also.
Tim and Bev
2015 F-350
