08-18-2013, 08:38 AM
Adding Shocks
Has anybody ever added shocks to their Cedar Creek? Looks like I have the bar for the slide out in the way on the outside?
Tim and Bev
2013 Cedar Creek 34RLSA gone trying to find my way back, Magnum 2800w inverter, 560w of solar.
2020 F-350
08-18-2013, 08:43 AM
Oc added them to his flagstaff if that helps.
Turbs
08-18-2013, 09:55 AM
Are you adding them to help smooth the ride?
Mike & Nan
2014 Cedar Creek 36 CKTS
2013 Ford F-350 4X4 Dually
08-18-2013, 10:15 AM
Yes, and I think it might help with my toilet bowl emptying when going down the road, it splashes out.
Tim and Bev
2020 F-350
08-22-2013, 06:17 PM
you have to drain the toilet before travelling. nothing you do will stop the water in the bowl from sloshing out while travelling. turn off the water pump or turn off the tap if you are hooked up to water and then flush the toilet until empty.
18 3500 denali duramax cc srw
silverback 31b2
08-22-2013, 06:37 PM
This is the first trailer that I have ever had that does this. Thanks, but that is what I already do.
Tim and Bev
2020 F-350
08-22-2013, 06:57 PM
If your emptying the toilet, then how are you getting water on the floor from it?
OC loves his shocks from what I have read on here about them.
08-22-2013, 07:06 PM
Sorry I was getting water on the floor till I started emptying the toilet.
Tim and Bev
2020 F-350
08-22-2013, 07:17 PM
38FL and I have never emptied the toilet before travel - and no water on the floor.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
08-22-2013, 07:41 PM
I think it is because of the 7000lbs axles and heavier tires, and not being loaded close to the higher capacity of the trailer. Everything in the cupboard on the other side of the wall from the toilet is always a mess also.
Tim and Bev
2020 F-350
08-22-2013, 07:47 PM
Certified Curmudgeon
36 CKTS, never empty the porcelain, no water on the floor. No shocks.
Mike Dropped
08-22-2013, 08:32 PM
The shock design on multi axle towable's, are not for up and down motion like motorhomes, car's and truck's. It is front to back motion between the axles. If you look at the hanger's you see they are at about a 45 degree angle. That is the reason for the air pin boxes, equal-flex type axle connections, etc., the Dexter air suspension, or MorRyde IS system, this all are designed to help smooth the units ride. I agree with Ducky, we had 7000# axles, changed to 8000#, then changed to MorRyde IS. NEVER had any water from the commode come out, and we've gone over some pretty rough roads. One time (before the IS system), we were on such rough roads, we had three cabinet door opened and broke some things, several pictures come off the wall, but not one drip of water came out of the commode. Actually, most places are taking any shocks off, if they are still on. A few years back, the shocks were twisting, bending, or coming loose. They would rub and cut the tires, causing a lot of damage to units. Before I added anything, I'd talk with Mike at CC, ask him to see what he thinks might be happening in your situation. I'm sure they can come up with an answer.
Hope this helps and God bless,
Mike
Mike and Judy
Wherever we are parked is our home
2009 - 36RD5S
2007 - Dodge 3500 6.7 Cummins
May God bless
WA8MRU
08-22-2013, 08:53 PM
Do you have any contact information for Mike?
Tim and Bev
2020 F-350
08-23-2013, 10:43 AM
Tim,
Here is the contact info for Mike Antal:
Mike Antal
Technical Retail Service
Service Dept
Forest River, Inc
Cedar Creek Division
501 Hawpatch Dr
Topeka, IN 46571
260-593-2326
Fax: 260-593-3333
email:MAntal@forestriverinc.com
Only have talked with him a couple of times. They have changed people there, in the last few months. But the attitude with Cedar Creek is still the same, customers first!
God bless,
Mike
Mike and Judy
2009 - 36RD5S
May God bless
WA8MRU
08-23-2013, 10:47 AM
Tim, I forgot to tell you, Mike at CC will need the last 7 numbers of your VIN number. Sorry about that.
God bless,
Mike
Mike and Judy
2009 - 36RD5S
May God bless
WA8MRU
08-23-2013, 11:02 AM
Mod free 5er
My Flagstaff has torsion axles and the shocks work great for stopping the bounce of the trailer as well as preventing it from telegraphing to the truck. With torsion axles, there is no back and forth action like on spring suspension and the walking beam. We leave the coffee maker on the rear counter and have towed to FL twice and from NC to Goshen, IN to Trenton, MO and it never moves. Don't know how the shocks can twist and cause damage unless the mounts bend or break.
08-25-2013, 11:11 AM
X2 on the shocks like OC did it. Great mod.
08-25-2013, 11:31 AM
Make sure your tires are balanced. I always had my TT tires balanced. Always got a look from the tire guy, why?, I told him so my beer would be fizzy.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
08-25-2013, 02:57 PM
I never had problems with water splashing out in my 2008 37RDQS even before changing the suspension. However, I do have the TrailAir on the front of my 5er. I also now have the MorRyde IS and their disc brakes on it now. I'll never have another 5er without it.
John
08-25-2013, 03:13 PM
I also was thinking about shocks. To keep from flipping my shackles. Had it happen last trip out, now I am real gun shy.
