Old 05-04-2016, 12:35 PM   #1
mekkerlc's Avatar
Adjusting Slide-Outs to Close Tighter?
When closed up, A few of my slides seem to be tight on one side (I can't put my finger tip in) and a decent gap on the other (where I can put a whole knuckle in-between). Same goes for the top and bottom on some.
Is there a way to adjust these? Aside from taking it to a dealer, I'd like to do this myself. I hope its it just a few adjustments to bolts, etc...
I've search this forum and youtube, with no luck!
Thank you!
Luke & Carolyn
2012 Cedar Creek Silverback 35QB4
2013 Sierra 3500HD Duramax CC SRW SB 4x4
Andersen Ultimate Aluminum 2 Gooseneck Mount
mekkerlc is offline   Reply With Quote
Old 05-04-2016, 03:39 PM   #2
dieselguy's Avatar
Here's a PDF ... start at page 16. Slide adjustment is tedious, but can be done by an owner. Do not tighten the 3 nuts up together on the slide bracket. Thw space there is for a reason ... cylinders have more travel than the slides physically can move.
https://www.lci1.com/assets/content/...de-out-web.pdf
dieselguy is offline   Reply With Quote
slide, slide out
