Old 05-05-2019, 06:55 PM   #1
Derek10's Avatar
Air Bags, yes or no?
I have a 2018 Ford F350 SRW pulling a CC33IK and was wondering if it makes a big difference? TIA.
Name:	My Truck and RV.jpg
2018 Ford F350 Diesel
2019 Cedar Creek 33IK
Nights Camped 2015=30, 2016=27, 2017=43, 2018=62
Derek10 is offline   Reply With Quote
Old 05-05-2019, 07:45 PM   #2
Now a "Top Member"
EdJunior's Avatar
It looks like you're sitting pretty level. Is there a specific issue you are having? I had to have air bags on my last two trucks to help level the squat, but so far on my '19, which looks just like yours by the way, except mine is a 250, I have not needed air bags. I have the camper package which boosts the weight rating a bit, and actually levels the truck out perfectly when I hook up my 5th wheel.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 05-05-2019, 09:05 PM   #3
Otegoans's Avatar
I have air bags on my GMC and run 5 to 7 PSI in them to achieve a level profile, depending on how much stuff DW thinks we need to take. From the picture you posted it looks like you're sitting pretty level. If you stand back and look at your Truck and camper hooked up and loaded on a reasonable level surface, you want to see truck and trailer sitting level. You'll get the best towing experience if the truck and trailer are level. Adding air bags will ensure the level profile; if needed; as the trailer is loaded. Hope this helps, God Bless, Ken
Otegoans
Ken and Wendy
'15 silverback 29RE
'13 GMC 2500HD
Duramax/Allison
Otegoans is offline   Reply With Quote
Old 05-08-2019, 06:14 PM   #4
Old Bleu's Avatar
We tow a 33IK as well, and I added air bags to the Ram 2500. The truck leveled out pretty well without them, but I add about 10 lbs to them before hitching, and think they help a bit with stability.
2019 Cedar Creek Silverback 33IK
2016 RAM 2500 Laramie Cummins Turbo Diesel
Old Bleu is offline   Reply With Quote
Old 05-08-2019, 06:41 PM   #5
B and B's Avatar
I have a 2016 F 350 with Snowplow Package and my truck sits level with 16,000 on it. No Air bags needed but I am planning on them.
Old 05-08-2019, 07:04 PM   #6
I leveled my 2017 F250 4x4, so the airbags help level it out when the trailers on it. The truck rides a lot better when unloaded and 5 lbs in the bags. I guess it's due to the truck riding on the bags and not on the springs. I have the camper package in my truck and it used to beat me up unloaded before the bags. I went wireless, worth every penny.
2019 Forest River Cherokee 294BH Limited
2017 F250 4x4 Diesel
Pure Luck is offline   Reply With Quote
Old 05-09-2019, 02:57 PM   #7
Have Wireless air system also on 2017 F350 diesel. We have a Silverback 33Ik. Truck sets level when hooked up. We use the air bags not to level but to eliminate the float feeling on our great highways. Would not be without them.
Rich5117 is offline   Reply With Quote
Old 05-14-2019, 03:47 PM   #8
On my CC 36CK2 we have the air ride hitch and was told if I put air bags on my truck it would be to bouncey. We townitnwith a 2018 Chevy 3500 Duramax and is pretty level.
jmcclocklin is offline   Reply With Quote
Old 05-14-2019, 04:38 PM   #9
Jestercyco's Avatar
I opted to get Tibrens instead of air bags and have been pleased with the ride. When you need the extra lift it works well. When not pulling a trailer it is not changing the ride height. They were $279.00 at Amazon when I bought them.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 05-14-2019, 05:23 PM   #10
I have the same scenario / setup. Don稚 need airbags but already have them.
I added ranch rsx9000 shocks which really helped the rebound when using the air bags.
Vikes79 is offline   Reply With Quote
Old 05-17-2019, 11:00 AM   #11
TexasGolfBum's Avatar
Have them on our Ram 3500 and wouldn't ever go without them.
TexasGolfBum is offline   Reply With Quote
Old 05-17-2019, 11:11 AM   #12
Cardinal 3825 FL with 2019 F350, level without air bags. The F350 is a lot better then the F250.
whj469 is offline   Reply With Quote
Old 05-24-2019, 09:25 AM   #13
Airbags on 2013 Chevy 3500 DRW
Added airbags to our truck only to keep the level, not increase load carrying capacity. Worked great. Only pump up to 25# when towing.
karpcbk15 is offline   Reply With Quote
Old 06-09-2019, 01:37 PM   #14
Harry043's Avatar
Firestone Airbags
So what did you decide? I have had Firestone airbags on my last 2 trucks, 1st was a Ram 2500, and I was pulling a Open Range 38 foot 5er, too big for the truck really, but it did fine with the airbags pumped up, you could actually see the ass end of the truck raise up a few inches. But, too much for the truck, so I bought a 2012 SRW Ram 3500 with a high output Diesel and added the same Firestone airbags. Love them, wouldn't be without them. Just bought a new 5th wheel, 2700lb pin weight, the truck handled it effortlessly, 6 speed automatic, but I pumped up those air bags anyway.
BTW - They are a fairly easy install if you have any mechanical ability at all.................
God created the fishing pole to keep the truly gifted from ruling the world!
Harry043 is offline   Reply With Quote
Old 08-13-2019, 03:15 PM   #15
mbbutler's Avatar
Airbags aren't your problem. Ford brakes are. Upgrade your brakes.
mbbutler is offline   Reply With Quote
Old 08-13-2019, 03:27 PM   #16
I just had Kelderman rear air springs installed on my Ram.
So far so good.
https://kelderman.com/shop/2014-ram-...il-replacement
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 08-30-2019, 05:21 PM   #17
I知 sorry, I have a 2018 Ford F-350 CC SB SRW and tow a CC 34RL2 that puts me near max GVW. I have towed thousands of miles in mountainous terrain. There are no issues with the brakes on these trucks. None.
Fireman1 is offline   Reply With Quote
Old 09-02-2019, 04:50 PM   #18
Couldn't agree more. I run a 2017 F350 DRW and haul 16k# with NO braking issues whatsoever. The 6.7's also have a good engine brake which works well with the 6 speed transmission to slow down the truck and respective load.
And something to remind everyone is that the TV should not be doing all the braking. When the towed RV's brakes are adjusted and configured well with the brake controller, it should do a good amount of braking and not be relying solely on the TV.
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
jd4010 is offline   Reply With Quote
Old 09-04-2019, 09:46 PM   #19
SlowrideHD's Avatar
I have Firestone bags under mine with the frame mount compressor, mainly to level it while hauling a 17,000 lb dozer on a 9,000 lb gooseneck. Definitely never a problem with brakes on my truck, even hauling the dozer.
My truck sits pretty level with my fifth wheel and ten lbs of air. I even occasionally look at my levelup indicator while it is hitched up and on level ground the camper is level as well.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
air bags
