Old 12-16-2015, 10:14 AM   #1
Air Conditioners in Florida
It seems like the AC cooling our living room in our COTTAGE cycles off for quite a short time. The 2nd over the B.R. and Bath cycles off for a longer period. Is there anything unusual here. I believe both AC's are 13.5 k and the one over the bedroom cools a smaller area. Both do a good job of cooling but i am concerned about the cycle time of the forward most ac.
Patrick45 is offline   Reply With Quote
Old 12-16-2015, 10:34 AM   #2
Left Coast
Take outside covers off and insulate with the foil bubble wrap from HD or Lowes, and add alum. screening to vent openings
Old 12-16-2015, 01:28 PM   #3
dieselguy's Avatar
If one of the air vents is blowing air on or near the main thermostat ... change the vent direction. Your bedroom A/C should have its own TStat to make cycling differernt.
dieselguy is online now   Reply With Quote
Old 12-16-2015, 01:32 PM   #4
Bluepill's Avatar
Some t'stats have an adjustable "Differential" or "Anticipator" setting.
2008 Itasca Meridian 37H
Old 12-16-2015, 01:50 PM   #5
turned that vent away from the main t stat - will see
Old 12-16-2015, 01:54 PM   #6
Might the problem be that the front/main zone was set to medium fan and the back/second zone is set to automatic?
Lazy Days set the thermostat (other than temps) when we trialed the unit at their place. We had not touched this before. Maybe MY BAD.
Old 12-16-2015, 02:13 PM   #7
dieselguy's Avatar
The fan setting might make a difference ... might not. The difference in the automatic setting compared to an actual fan speed is the compressor cycles on and off with the fan continuing to run on say medium fan. Automatic ... it self selects the fan speed due to temp differential between set point and actual room temp. Also, the compressor and fan cycle on and off in automatic, not just the compressor. Read up on your TStat ... assuming it is digital, it may have an adjustable differential setting for each zone.
Old 12-17-2015, 02:20 PM   #8
edt
you should have a 15000 in living room and 13000 in bed room the sensor for bedroom is in the ceiling the living room is the thermostat all the ducts are tied together mine runs a lot in the afternoon because rear windows are in hot after noon sun
edt is offline   Reply With Quote
air conditioner
