Old 10-13-2016, 04:37 PM   #1
CC38EL's Avatar
Almost hate to ask this.....
but has anyone seen or possess a Load/Inflation table for WestLake tires?
I know or suspect most run at max for their given type, but it would be good data to know at what psi you can run with what weight.
It's not my intention to discuss the quality of or reputation of WestLake tires or other so called 'China bombs'. The rig came with these tires and I'm going to use them until there comes a time when I don't want to use them.
Thanks in advance.
Jim
2017 CC38EL Silverado 3500HD
CC38EL is online now   Reply With Quote
Old 10-13-2016, 04:47 PM   #2
wmtire's Avatar
If you are needing it for a SL309, here you go. If a different tire, you should be able to find it there on their website:
Westlake SL309 | Westlake Tires
2011 Flagstaff 831 RLBSS
Wanna know how I plan on cutting carbs next year?
With a pizza slicer.
Old 10-13-2016, 09:59 PM   #3
CC38EL's Avatar
Mine are CR class and the only info I can find is on the WestLake Philippines or Dubai sites.
I spaced the actual tire label, but will get it tomorrow.
Jim
Old 10-13-2016, 10:23 PM   #4
If you are looking for their ST tire line specs I was never able to find them on the Westlake website.
2015 F150 Ecoboost
2014 Palomini 142 CK
keith_h is offline   Reply With Quote
Old 10-14-2016, 10:35 AM   #5
CC38EL's Avatar
I had your luck as well. Mine are Westlake CR960A ST235/85R16. Also advertised as Goodride.
I'll keep looking......
Jim
Old 10-14-2016, 10:40 AM   #6
wmtire's Avatar
Gotcha. Lionshead (who is the company that provides a lot of Forest River products tires and wheels) have them on their website:
Maybe this will help:
Westlake Radial Tire
Many tires (regardless of brand) just about have the same load/inflation table.
Old 10-14-2016, 12:04 PM   #7
One thing to keep in mind is that each tire may have a different amount of weight that it carries. On my last trailer that I had weighed at a rally, the left rear tire carried almost 800# more than the tires on the curbside. In my opinion I would put the tires at max inflation and leave them there.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 10-14-2016, 12:18 PM   #8
BandJCarm's Avatar
Underinflation causes problems. Inflate all to 110 and leave them there.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 10-14-2016, 12:45 PM   #9
CC38EL's Avatar
Each tire is rated at 4079 lbs at 110PSI. For my rig, that is 16,316 lbs of carrying capacity.
Hooked up, on the scale, I weigh 12,440 lbs on the trailer axles. That's half loaded (some of my clothes, all of my tools and dinnerware/cookware, full propane, full water, no people/pets/food).
16316-12440 = 3876 lbs of unused capacity for those tires.
Over inflation is just as bad as under inflation. And we're not even talking about the amount of bounce a fifth wheel is subjected to with tires that are hard as a rock.
If I can find a load/inflation table, I might get more miles out of those tires, less of a chance of a 'tire bomb' event, and less wear and tear of the coach.
In the absence of that information, I run max psi.
Jim
Old 10-14-2016, 02:09 PM   #10
mike.t's Avatar
Maybe
mike.t is offline   Reply With Quote
